Furuno Gp32 Help !
Hi i have posted this before but im still wondering if anyone on this website has a Furuno GP32 and is willing to offer a little help operating the system i am getting the hang of things but still bit sketchy. Just curious on how to insert GPS co-ords what format they have to be in to enter into the system , and also how to make it so i can follow a co-ord straight out to the spot . Any help or advice would be much appreciated.
living is fishing
Date Joined: 27/08/09
http://www
Mon, 2010-07-12 20:17
Date Joined: 25/05/09
Thanks for the Link i have
Mon, 2010-07-12 20:27
Thanks for the Link i have also found this. It is quite informative for such a small document. Ill give it a try. Never ever no unless you ever ever go. Cheers Starbug , any other help anyone else has to offer is also welcomed and much apreciated.
living is fishing
Not a problem. I dont have a
Mon, 2010-07-12 21:33
Not a problem. I dont have a GP32 myself, but there are manuals to download on the Furuno US website.
As for the format of the GPS Co-ords. It can depend on how the GPS is set up. This is user selectable. Probably the most popular is Degrees.Minutes.Decimal Minutes DD.MM.MMM, or Degrees,minutes,seconds DD,MM,SS.
Accurate
Mon, 2010-07-12 21:45
Very accurate units and easy to use.
Haven't used mine for 6 months or so I'm a but rusty.
Can't remember what units I have mine set at. Something like s115, 32, 643. To go to a waypoint, press GOTO and then select the waypoint.
I usually use highway view while navigating to a spot.
Hi big john , very
Mon, 2010-07-12 22:25
Hi big john , very interesting that you also have one of these units , if you get to use your unit soon any other information you could offer me about this system and how to use it would be Great, I find things alot easier to understand if people explain it to me or show me sometimes instead of trying t understand the reader manual as sometimes i feel they complicate things more then they have to be. Next time im out there ill check the boat on how it is set up , any more info would be great thank you guys
living is fishing
Simple
Mon, 2010-07-12 22:35
Easiest thing to do is plug it in and play with it in the driveway.
Just press buttons and see what happens. Its a very simple operating system.
I'm over 3000 km's away so it might be a bit hard to show you in the flesh.:)
DO i need to put the unit
Mon, 2010-07-12 22:48
DO i need to put the unit into simulation mode ? and turning it on in the drive way will not affect way point or gps operation in anyway? Also while in the driveway i can operate and get similair results to what i would get if i took her out on the water , ie way point direction to drive in etc ? 3000 km is a bit far but i would go that far for fishing if it would assist me greatly in the future.
living is fishing
Fine
Mon, 2010-07-12 22:59
Will be fine in driveway. That way you can have a look at the different nav screens, enter, edit and delete waypoints etc.
No need to use simulation mode.
Awesome as thanks heaps for
Mon, 2010-07-12 23:18
Awesome as thanks heaps for all the info , if i can master to use this system ill be stoked. one last question do i have to change the way that the co-ordinates are shown on the system from N XX.XX.XXX E XX.XX.XXX TO S XX.XX.XX E XXX.XX.XX
living is fishing
No
Mon, 2010-07-12 23:23
I've been using mine as per N xxx.xx.xxx.
I find some places and books
Mon, 2010-07-12 23:39
I find some places and books gives the GPS co-ord differently like S XX.XX.XXX E XX.XX.XXX is this the same or the gps co-ordinates different ? you couldnt use a program like google earth or anything to take co-ords could you ?
living is fishing
Same
Tue, 2010-07-13 00:05
I use them like you have just listed, but for the first set of numbers it could be two or three depending on the coordinate ie. E115 or S32.
