Fuel Flow
Submitted by Rick on Tue, 2009-08-18 20:53
Have been toying with the idea of fitting a fuel flow meter of some description in the boat.
Have a good idea of fuel consumption against miles travelled. More for watching fuel usage at different rev ranges and trim of the motor.
Just wondering how many boats are running them and how much benefit it is ?. The motor I'm running is a Mercruiser 4.2.
I'm sure there would be a few different types out there, curious to know peoples thoughts and experiences
PGFC Member
Navman
If you are running Navman gear they have all the bits and it runs through your GPS saving you the work of figuring it out
Tim
Date Joined: 26/09/06
Handy
Is handy. Have the GPS hooked up directly to the Suzuki and get the data directly out of the engine management system.
Have used the Navman inline system before as well but it kept on jamming up. Seems from what I have heard its pretty common.
BQ544
Date Joined: 22/10/06
Good
yes I run the Navman one and it's very accurate. You can adjust speed and trim and fine tune most economical way to set up your boat for the conditions. I have ran the inline Navman sender for over 5 years and it has never missed a beat.
Rick
Date Joined: 22/12/06
Furuno
Running Furuno 7000 GPS so unsure as what options are out there?
Is there a stand alone system that anyboby knows of?
Just the more you hook together if one part fails it's likely to affect everything........
PGFC Member
Tim
Lowrance
Lowrance do a stand alone system. In dash gauge and an inline fuel flow sensor.
mako magic
Date Joined: 03/08/05
lowrance
yeah as Tim just said a lowrance one, im still in the process of working out one for my boat , but unsure whether i want to tap into the gps or get one with its own seperate guage.
wouldnt touch one of the navman ones again had too many and heard of many shit themselves
Rick
Floscan
Just been looking their website,basic models right up to top of the range all depends how much you want to spend............as usual.
PGFC Member
Blank Cheque
Date Joined: 28/03/09
Totaly Agree with BQ544
great units simple to install easy to maintain.
Garry
