Flat battery
Submitted by Shane O on Tue, 2011-03-08 10:01
Hi,
Started Ol Yella in the driveway, no problems there. Got to the boat ramp and sounded like it wanted to start, but would not turn over. Disconnected the fuel, thought it might be flooded. Still nothing, checked the starter motor. It was very hot then I tried again and nothing... Just a clicking noise from the choke, check the battery indicator and the green light that says all ok was gone...
Is a bad thing to have a hot starter motor, or is it normal.
kempy
Date Joined: 28/05/09
normal if u have been
normal if u have been cranking it for a while
constablechris
Date Joined: 23/02/11
MateCheck all your
Mate
Check all your connections, battery and at the starter,
Battery probably just moved a mill or two in transport and lost connection.
Chris
sarcasm0
Date Joined: 25/06/09
Those green light indicators are crap
We have had several batteries with those now in my 4wd, had the light showing green, put the multimeter over the battery and had it less than 9 volts. My father also had this problem with a vehicle in their convoy while on the Canning Stock Route. Brand new battery, green light, no voltage.
Dont trust them, buy a multimeter.
squidvicious1
Date Joined: 22/07/10
earth is a big thing, look
earth is a big thing, look for corrosion around strap groundings.
