First Boat - Not the bargain first thought
Ok guys, I managed to talk my sister and her bf into going halves with me in a boat.
Found what we thought was a bargain, a 2009 Polycraft Warrior 5.3m Front Runner with a 2006 115hp Suzuki 4stroke (~140hrs per tacho) on a 2009 dunbier trailer. Drove down to Bunbury, checked it out. Two things that caught my eye was a quite large chip missing from the cavitation plate (bigger than a 50 cent piece) and the motor was not directly bolted to the transom, was bolted to an adapter which was bolted to the transom (looks like to suit a longer shaft motor).
Anyway, negotiated a good price subject to a test spin and test spin went well (other than wet). Unfortuantely due to the conditions, me not knowing the recommended rev range and the GPS being set to km/h I didnt notice at the time that it appears to be substantially under propped. (First trip out it was doing ~6200rpm at WOT for ~28knts, max should be 6,000rpm).
Now just had a call from the mobile mechanic who is doing a service on it and who thinks it has seriously hit some reef. The skeg is slightly bent and on closer inspection can see evidence of repair/welding and the propellor shaft is bent $$. Looks like the previous owner has repaired the skeg and stuck on a replacement prop (the wrong size).
Ohwell, welcome to boat ownership I suppose. Time to Bust Out Another Thousand.
Any ideas who can replace the propellor shaft? Mechanic reckons All Boats is the go being the Suzuki dealer.
Aaron
Pretty sure most polycraft,
Pretty sure most polycraft, and poly boats in general have an adapter plate for the motor. Usually you bolt into SS and the SS bolts onto the poly.
strike_zone
Date Joined: 09/09/10
bad news
i hate to tell ya but i think you will be pulling out a lot more than $1000 to fix that
Thats for sure. It was like
Thats for sure. It was like $2500 for a new gearbox for my old 40hp 2st.
mako magic
Date Joined: 03/08/05
$7500 for a honda 225hp 4st,
$7500 for a honda 225hp 4st, but free under warranty luckily
thesupervisor
Date Joined: 10/06/09
how did they fix under
how did they fix under warrenty?
was user error ?
getting the bottom line final answer from a bunch of blokes that use false names and put smiley faces at the end of paragraphs is not the best place in the world to get the information you seek.![Wink](http://www.weldingweb.com/images/smilies/wink.gif)
mako magic
tooth chewed out, no user
tooth chewed out, no user issues, and a great honda customer service
Oracle
Date Joined: 22/11/10
agree about honda service
had a major issue with my old boats 115hp. Was a dead duck. Got lots of quotes to fix and all basically selling me a new motor. 10 yr old and honda fixed it under warranty still. Legends!
smash
Date Joined: 01/12/10
$7 1/2 K!!
shee-it, thats rediculous, another couple of grand and you could buy an entire Hyundai car!
Theres only a couple of dozen or so parts in a lower leg!
Andy
Date Joined: 08/10/05
prop shaft
Any machine shop will be able to straight the prop. when the box is dissasembled to remove the shaft the mechanic will be able to see is there is any damage. Thow in some prop shaft seals and off you go. i get a quite a few straightened and have not had one back. had one done today, cost $75 300- 400 should see the shaft done with labour and seals.
aaasnapper
Date Joined: 15/01/10
Get the parts from america
Get the parts from america will probably be half the price of local.
http://www.boats.net/parts/search/Suzuki/Outboard/2009/DF140/TRANSMISSION%20%28DF140T%29/parts.html
null
Rod P
Date Joined: 20/05/08
Dont pull down a gear box
Dont pull down a gear box unless you know what your doing. There are shims, spacings, tollerances and all sorts to under go.
What area are you in?
VaSSagO
Date Joined: 09/12/09
Cheers guysWell sounds like
Cheers guys
Well sounds like best case scenario is ~$800-1,000 on the assumption nothing else is damaged, just a bent prop shaft
Looks like ~$600 for a new shaft, ~$300 for a new shaft from the US (thanks aaasnapper) or ~$130 for it to be repaired (xrayed and straightened). And then labour + seals etc on top of that
Located NOR in Padbury
seaswirl
Date Joined: 29/08/10
USA parts
I got a brand new gearbox for my optimax 225 from the US delievered for $2500.....thats NEW not reconditioned!!!!
quindieselbrad
Date Joined: 01/09/10
may i ask which yard in
may i ask which yard in bunbury u bought it from?
Catchn dhuies off the smell of an oily rag :)
VaSSagO
Bought privatelyIf it was
Bought privately
If it was from a yard I would haev a chance of getting them to foot the bill
VaSSagO
Just under $1k to fix
Just under $1k to fix including repairing the large chip missing from the cavitation plate
Now to take it back out and see what the motor does with the prop size on it currently
quindieselbrad
not too bad , i hope the prop
not too bad , i hope the prop is gd and no more dosh needed to get u out havn fun, all the best mate :)
