First boat
Submitted by Tim1511 on Wed, 2018-02-28 19:53
Hey guys I am looking at buying my first boat and am after some advice. My price range is around the 6-7k mark am hoping for something I can fish offshore with and do the odd rotto trip with. Is there anything in particluar I should be looking at ? Also how many hours is a lot for an outoard? I’m currently looking at a 19ft guardian with a 140hp 2001 Mercury outboard. Any advice would be great
Tim
get whatever your looking at
get whatever your looking at thoroughly checked out. transome , hull etc. we bought a 7k boat and it cost us a whole lot more to fix up in the end.
dont rush into getting one as you may get bitten. as far as hours goes it depends on the condition of the motor, you can get one thats 15 years old with only 100 hours and can be worse than one thats done 600 hours.
Vinesh87
7k is not a lot for a 19ft
7k is not a lot for a 19ft boat unfortunately
If going glass make sure the stringers are not rotten!
In terms of motor i have seen well maintained private 4 strokes doing over 2000hrs and commercially over 7000hrs. My last 2 stroke had 700hra on it and still goinf strong!
Have a good look at the trailer these can cost big bucks to fix up also!
Good luck!
Tim1511
Date Joined: 24/01/13
Cheers for the advice, I was
Cheers for the advice, I was originally looking at something a bit smaller around 16-17 ft but the 19ft guardian on gumtree caught my eye because of the outboard which the guy reckons only has 400 hours on it.
The one thing to consider
The one thing to consider there is the weight of the boat and the amount of fuel she'll drink, won't be cheap to run.
pelagicyachts
Date Joined: 23/02/11
some good advise above - I
some good advise above - I will chip in with - what are you towing with?
there are some good value older boats forsale - link below is a Penguin Phantom - good little boats and this one has a late model engine and good trailer on it asking 4500
Remember the asking price is just that - never make an offer with asking first "what would you take for it " sometimes the answer is surprising!
Any hull you are looking at I would ask the kangaroo court (that's this forum!) for an opinion - lots of good knowledge and experience on here
https://www.gumtree.com.au/s-ad/armadale/motorboats-powerboats/penguin-fibreglass-17-ft/1176561673
Cruise Control
Date Joined: 03/11/10
Plus 1 for the phantom,
Plus 1 for the phantom, great little boats but need to make sure stringers are not rotten. Also 60hp 2 stroke IMO is underpowered. A mate had one with 70 on it, good for 29 knots. I had one with an 85 good for 34 knots, a 60 might struggle.
pelagicyachts
poss a bit under but not by
poss a bit under but not by much - not many days you can hit 29 knots on the ocean in a 16 footer :-)
16 to 17 foot would be ample
16 to 17 foot would be ample to go to rotto. we had an 18footer and fished 20nm out . so it is dooable. tow weight as mentioned is a big thing, if your tow weight on your vehicle is under the weight of the boat and an accident occurs your not covered.
as mentioned the stringers and transome need to be checked thoroughly as well as the hull, look for any patched areas or repainted areas, not always but often it means there has been some damage somewhere along the line
Tim1511
Cheers for the feedback guys.
Cheers for the feedback guys. I will be towing the boat with my dads toyota prado. Haven’t really thought much about fuel consumption I guess that’s something I should look at more. There’s are the two I’m looking at the moment
https://www.gumtree.com.au/s-ad/wanneroo/motorboats-powerboats/1
https://www.gumtree.com.au/s-ad/beechboro/motorboats-powerboats/18-ft-mustang-price-reduced-6500/1176134168
the mustang doesnt look to
the mustang doesnt look to be a bad boat but the only issue i see straight up is the area in front of the motor seems a bit low and water could come up through in rough conditions.
pelagicyachts
id be more worried about the
id be more worried about the fact he has only had it 2 months...... ! why selling after such a short time??
Silver Fox
Date Joined: 19/06/14
+ 1
Go the Phantom . Great little boats. Mine got completely stripped down and rebuilt from the ground up. New ribs stringers , transom and floor ( massive job but well worth it ) Turned her into a centre console with a pod and a Yammie 2 stroke 90 on the back . Goes like a shower of shit....:)
