Engine stalling when cold
Submitted by grahaml on Wed, 2017-03-22 16:09
Gents
i have a Yamaha 100 four stroke done 330 hours and its just recently started giving me grief it will fire up when cold if a give it a bit of revs but stalls as soon as I put it into ggear if I warm it at 1000 to 1200 rpm for a few minutes it will be fine for the rest of the dday any thoughts on what's causing this
its not due a service till 400 hours
Samo76
Date Joined: 17/08/08
IAC valve
IAC valve
Here I am...and there you are.
Auslobster
Date Joined: 03/05/08
Thermostat maybe?
...if it's stuck open, while take a while for cooling system to "warm up".
North Coast Marine
Date Joined: 23/05/16
Depending on how old the
Depending on how old the motor is it may use Carbs and not Injectors, if this is the case then there may be some debris in the passages. The carb models have a very complicated choke/idle up system that can present issues as the hours increase, Second the thermostat issue, causes all sorts of havoc, give me a call if you want a hand 0409118903
Did Yamaha make a four
Did Yamaha make a four stroke 100 that wasnt EFI?
Common problem on the 115 Yam 4S was the TPS, which causes similar symptoms to that mentioned.
Travisd
Date Joined: 07/05/11
Throttle indicator sensor
my two cents
Baron Sportsman
Just the depth that Varies
Travisd
Or
a throttle position sensor same thing
Jetpower fixed a friends that did that a month or so ago
Baron Sportsman
