engine saging
Submitted by Sea goat on Wed, 2020-12-02 10:12
Hi guys.
i have a 200hp 4stroke mercury.
i have noticed over the last week or so that when i park it up i trim it up about midway. a few times by the next morning the leg is sitting on the ground. still seems to trim p and down ok, but just doesnt seem to hold the position.
any ideas? cant get it into the shop until early jan, and really want tobe using over the next few weeks for the crays.
cheers!
Goat.
dodgy
Sounds like an internal seal
Sounds like an internal seal is leaking.
You may need to replace the
You may need to replace the seals in the trim rams. Worst case being replacing the ram itself. Had the same issue years back with my first boat
Sea goat
Date Joined: 26/03/17
ANY IDEAS WHETHER IT WOULD BE
ANY IDEAS WHETHER IT WOULD BE OK TO TILL USE if it is a busted seal?? I CAN PUT SOMTHING in to stop it sagging when im driving to and from the ramp...just didnt wnt to get stuck with it fully down at the ramp and not be able to retrieve....
Ring the Merc dealer
They'll give you the best advice. Sucks on a new motor. Are they saying they won't do an immediate warranty job on it? From them, find out where the pressure valve is on the tilt/trim assembly. Worst case scenario, if it does actually fail to lift at the ramp, you undo this valve ( normally just a big flat-blade screwdriver required) and lift it up, then get someone to lock it back up, and put a block under it. I've had to do this myself with a motor some years ago. In the meantime, leave a block under it at home to take the weight. HTH.
Scotte
Date Joined: 07/12/06
Check that the manual relief
Check that the manual relief valve is tightly closed.
Have seen a few outboards do what yours is doing because it was1/8th of a turn out.
Jackfrost80
Don't know if you have a
Don't know if you have a torque wrench capable of checking but it should have the required torque for the relief valve in the manual as mine does for my Suzuki.
squalis
Date Joined: 23/11/14
merc
Put a block of thick wood between the end of the trim and tilt ram cylinders and the height adjustment bracket .Use pine or other softer wood to relieve strain while on the move or stationary . Will ensure a longer life of the trim and tilt system.
Sea goat
awesome. thanks guys. have
awesome. thanks guys. have got a block of wood in now, and have it booked in early jan to get looked at. spoke to the dealer and in mean time will check the manual relief valve, hopefuly this sorts it out!
squalis
merc
Correction to my previous post. the block of wood goes between the bottom and top of the engine mounting bracket. the principle is to keep strain off the trim and tilt mechanism. It will protect the motor and seals. You remove the block for operation of the motor in the water .All the best, i have not looked at the stern of the boat in ages..
dano83
Date Joined: 25/05/12
This happened to my boat
This happened to my boat when I first got it... probably leaking out the seals.. I leave my motor fully down when not using it to keep the ram fully inside the Case ... they tend to dry up and when you move them. Straight down if a dry bit of built up salt or just dry The seal doesn't like it causeing it to eventually fail
also pressure on the ram and seal constantly when no in use kills them Also
it might just be a very slow leak just keep an eye on it untill fixed as long as you have some fluid and trims working. Ok you should be good.. don't use it if the trim is straining
Swompa
my motor has done it since
my motor has done it since new. it is a 2009 motor and is still operating fine.
