Combo for deep water Jigging/Bottom bouncing
Submitted by naylor_1 on Tue, 2011-01-25 15:03
Hey fellas, im looking at getting a new combo for the deeper water up to 400m. Just wondering what rod and reel u all use for this type of fishing and any recomendations? budget around 1000$
Cheers Matt
JohnF
Date Joined: 07/07/10
Hey Matt, hows it
Hey Matt, hows it going......$1000 is right in middle ground....wont get ya the top shelf stuff but will be pretty good.
Are you sure you will do much in the 400's.......we did a bit of jigging in 250m up at Jurien earlier this month and I have no penchant for doing it again.......just hard work and a lot of winding......120m is enough for me, as most of the fun is in the strike....not cranking up 390m of line and 20 kg of limp fish.
For 400m bottom bouncing, I would strongly recommend an electric but think this is well outside your price range and no good for jigging......Chrisp used a Saltiga overhead at Jurien and it seemed OK....I used a Stella 20,000 (which will blow your budget unless you literally use a broomstick for a rod) and did not have much fun to be honest, and 400m would require PE5 on a 20,000....
I think a strong overhead would be the go........plenty of options but have you thought about one of the bigger Shimano OceaJiggers.....absolute ducks guts for jigging (I have the 1500 size for PE3 stuff.....awsome reel but only JDM spec....) and the larger ones would be sweet for heavier line classed for jigging and would bottom bash as well as they have heaps of cranking power....
But maybe a 2 speed may be the go? Others will know better.
John
Oceanside Tackle
Date Joined: 23/07/09
Jigging Master
Matt, were currently got a Special on, feel free to take a look; http://fishwrecked.com/forum/oceanside-tackle-and-marine-australia-day-specials
This outfit below is apart of that link;
Jigging Master PE8 "Jigging/deepwater/bottom bash" Combo with freebies
Combo consist of;
*Jigging Master Power Spell PE8 reel
* Jigging Master Three Kings Heavy rod PE 5-10
Normally $1489 ** Special Price $1199
** FREE JM Jigging DVD's
** FREE JM Fishing Top
** FREE JM Fishing Cap
** With combo purchase
Oceanside Team - Specializing in Jigging for demersal, Super Deep Fishing and Cockburn Sound Pink Snapper.
Don't forget to ~ Like us on Facebook ~
Phone #(08) 9337 5682 - Shop 4/364 South Street O'Connor - OPEN 7 Days
Alan James
Date Joined: 30/06/09
Penn International 16vs ???
There was a new one in the for sale forum not so long ago for <$400.
naylor_1
Date Joined: 15/02/10
Cheers john, wont be doing
Cheers john, wont be doing alot of fishing at that depth but it could always be used for shallower bottom bouncing trolling ect so i just want the line capacity there for the days i can get out that far. havent really had much to do with the oceanjigger might check them out, i had a look at the saltiga 50 today and it seemed good, any recomendations for rods to suit that reel?
Might have to pop into oceanside and check that jm out also.
cheers Matt
No point expecting to use the
No point expecting to use the same outfit for trolling ... trolling 80lb braid?
I'm using an Accurate BX600 with 600m of PE6/80lb on it, with a Synit DeepShot Seriola Pro and its a good combo. I'm thinking of filling up my other BX600N with PE5/70lb to get the line down a bit easier on those days with the heavy currents.
Feral
Date Joined: 01/11/06
penn 16vsx . .. ive got the
penn 16vsx . .. ive got the 30vsx and 50vsx for the deep stuff and trolling
naylor_1
I have always used my b/b rod
I have always used my b/b rod and reel for trolling with 10 or so meters of lighter mono leader and it does the job, i dont do enough of it to justify having a dedicated set up, basically im just after a good rod and reel to handle 600m or so of varivas pe5, i wouldnt imagine the 30vsx would be any good for jigging?
For trolling, you can always
For trolling, you can always use something cheap like a TLD.
The Penn reels are nice, but jigging with a 16VSX? No thank you!
I have these figures for the Accurate reels;
* Extrapolated from other values
I actually got 600m of PE6/80lb onto the BX600 and 350m of PE8/100lb onto the BX600N, but I reckon I'll get damn close to 600m of PE5/70lb onto the BX600N when I get a spool of that in to try. The benchmarking for the Daiwa Saltiga Boat Braid has been so good I really don't expect the PE5 to break under 80lb, the PE4/55lb is breaking @ 68lb.
Simon C
Date Joined: 01/05/07
the other rod that is perfect
the other rod that is perfect for this is the smiths Marianna if you can find one, made for really deep jigging. I use a SOM 120 with a SMiths WGJ EX and find it excellent in 250-300m. As till said I think PE4-5 is probably smarter as heavier line makes it harder to get down.
Luke had one for sale cheap
Luke had one for sale cheap awhile back?
naylor_1
There is a mariana 200 for
There is a mariana 200 for sale at the moment, it states its rated pe4 and 300g jigs would it handle pe5 and maybe up to 500g jigs? also till were did u get your bx600 from and was it 600m of daiwa boat braid u have on it and would it suit that rod?
Can't really comment on the
Can't really comment on the smith, never used one myself 500g is a big ask for a PE4 rod though!
The Accurate BX600 is too big a reel for PE5 and the Smith. I have 600m of PE6/80lb Daiwa Saltiga Boat Braid on mine.
Remember luke used to use his smith mariana 200 with a SOM L50 which only weighs 480g, the BX600 weighs 740g, even the BX600N is 680g.
