Try googling phoenix, they make some very good coatings. they are in O'Conner. One boat trailer I used phoenix coating on is in better condition than the galvanized trailer under the Quintrex, they are both about 17 years old. Regards Marrisy.
Hey Sea hawk, just use cold galv. Probably best to buy in a spray pack as a 4 litre tin will set you back around $250. But it's real good stuff if applied correctly.
Thanks Sea-Kem, yeah I've tried some spray can ones, sanded it back but seems to go on quite thin. I wil try putting three coats on. Last time the surface rust came through after a couple of months. Was thinking of brushing a thick coat on. Cheers.
marrisy
Date Joined: 08/09/11
phoenix
Sea Hawk
Date Joined: 02/08/15
Thanks Marrisy, sounds good,
Thanks Marrisy, sounds good, will look into it.
Feral
Date Joined: 01/11/06
The stuff we use up here on
The stuff we use up here on rio tinto marine areas is jotun barrier 77 . Or international interzinc. Both are 2 pac paints but they are great
Sea Hawk
Thanks Feral, does that
Thanks Feral, does that Barrier 77 come in a Galv looking color ?
Ashen
Date Joined: 22/03/13
Which brand?
G'day Andy. Any particular brand you recommend or are they all the same. Had a look at Bunnings and theres 6 different brands of spray!
Yeah sod Bunnings, go to
Yeah sod Bunnings, go to Dulux or Robayne they are the suppliers I use.
Sea Hawk
Just keep building up the
Sea Hawk
Lukastoy
Date Joined: 04/10/16
trailer work
When I have done mainlanders on trailer I use structural steel gal paint from Bunnings.3 step process cleaner, primer ,gal.
For my best results I use baby roller 100mm in foam. Gives great flat finish and bright gal coating.
upg
Date Joined: 25/06/07
Blast and galv bar
Blast and galv bar
