Cleaning Boat Windscreen -What to use
Guys what do you recommend on your boat windscreens.
I have a quintrex-no wipers and the sticker on the screen advises just to use water but it still gets lots of water stains etc.
sammy85's picture
Date Joined: 31/08/10
 Car Polish helps it bead off
Wed, 2013-12-04 07:38
 Car Polish helps it bead off after aswell
Happy Hooker's picture
Date Joined: 12/11/08
Put plexus or vuplex in search engine on the left
Wed, 2013-12-04 07:48
You will get a fair amount of info on this subject.
Saulty2's picture
Date Joined: 28/05/10
i use an old 2litre? sea sol plastic bottle
Wed, 2013-12-04 08:51
fill it with water and some dishwashing liquid ,{i use morning fresh } connect to mains , spray/ wipe /  has done the job on the whole boat for the past 6 years
Date Joined: 23/11/09
Here is a trick from a detailer
Wed, 2013-12-04 09:36
 You will probably think im a troll for this but wait for it.....
STEEL WOOL !
Yep, works a treat. we use it on the car windows, boat windows, shower screen.
Needs to be the one with the soap in it. You need to check that your windscreen is glass not PERSPEX/PLASTIC or it will scratch the hell out of it.
And dont do it on window tinting.
It removes everything, water stains, calcium etc. Once done with the steel wool, hit it with a wax of somesort.
Just find a piece of glass somewhere, or do a bit on the corner of your shower screen and you will see what i am talking about.
Brings it up like new.
Willlo's picture
Date Joined: 07/10/11
IF its glass Ran X,if its
Wed, 2013-12-04 15:20
IF its glass Ran X,if its Perspex dishwashing liquid.
 Call Sign - BZ785
Haynes Hunter Prowler CC
Stevo81's picture
Date Joined: 16/04/12
 Yep rainex the go
Wed, 2013-12-04 20:27
 Yep rainex the go
Mason85's picture
Date Joined: 21/04/13
rainex
Wed, 2013-12-04 20:54
rainex
Thu, 2013-12-05 19:00
shonky's picture
Date Joined: 22/04/12
vinegar
Thu, 2013-12-05 04:18
give vinegar a go mate, works a treat on the house as well getting stains from bore water as well anything else off without the hard scrubbing. stinks a bit but a good rinse after will sort that.
This habit is getting expensive!
joel231's picture
Date Joined: 18/09/12
 i work in an underground
Thu, 2013-12-05 18:56
 i work in an underground mine and the windsreens all ways cop alot of crap from the salt water underground. we use this water spot remover www.pacer.com.au/content_common/pr-glass-cleaners_malco-water-spot-remover.seo works really well, just squirt on and rub with a rag then risnse off, to easy !
Cheers Joel
Plastex
Wed, 2013-12-11 06:56
Easy to apply, causes water to bead off for far far longer than Rainex and removes fine scratches as well
