Bore water marks on my fibreglass boat
hey guys just brought a lovely new house with beautiful gardens thanks to our bore. Unfortunately after last weekend I left the cover off the boat until the carpet dries. My whole boat is basically now covered in borewater marks/stains. Anyone ever had this happen or know how to get it off. Seems pretty well stuck
Terry's picture
Date Joined: 04/12/05
have you tried
Fri, 2017-05-12 17:11
 The famous, good old, CLR ?
Dirt's picture
Date Joined: 04/03/10
CLR
Fri, 2017-05-12 17:29
 Tried that mate faded it slightly but that's all
Vinesh87's picture
Probably have to cut and
Fri, 2017-05-12 18:09
Probably have to cut and polish. It's long and sucky haha
When i did my old boat it was 3 grades of 3m from course to fine to ultra finnesse!
 Citric acid based cleaners
Fri, 2017-05-12 18:54
 Citric acid based cleaners will do it.
Date Joined: 22/07/10
 Blitz aluminium and
 Blitz aluminium and stainless cleaner cleaner,leave for about 5 mins than copious amounts  of water.might need apolish after.
chris raff's picture
Date Joined: 09/02/10
 Dr Chemical could have the
Fri, 2017-05-12 19:37
 Dr Chemical could have the answer you seek .. might be worth a enquiry call
http://www.borestainremoval.com.au/
Reefmonkey's picture
Date Joined: 22/09/08
Jiff
Fri, 2017-05-12 22:04
 Jiff worked wonders on bore stains on our painted ali, might work on fibreglass too
 Dave J.
Date Joined: 05/05/06
diluted oxalic acid works a
Fri, 2017-05-12 22:06
diluted oxalic acid works a treat, but you will need to polish it. Ive got an old fibreglass boat and it works too good. Not sure about using on a new boat tho.
Bend over
Dirt's picture
Sat, 2017-05-13 05:27
Thanks heaps guys few good options there
gruntre69's picture
Date Joined: 15/10/16
 See my post here, not sure
Sat, 2017-05-13 09:50
 See my post here, not sure if it will work on bore water which is probably iron...
fishwrecked.com/forum/bait-board-repair
solly's picture
Date Joined: 11/09/05
Gumpsion
Sat, 2017-05-13 16:19
 ive use gumpsion the kitchen stuff and it works a treatand doesnt damage the gelcoat
There are two types of people ,do'ers and watchers
Right now the do'ers are the doing it
And the watchers are watching us do it
Date Joined: 28/07/16
Hey mate
Mon, 2017-05-15 07:51
 My grandpop had the same problem with borewater on hes white car he used calcium dissolver the enjo lime scale hero and it works a treat mate came off instantly pm me for more detail i have some here if u cant find any   www.enjo.com.au/calcium-dissolver-250ml.html
Date Joined: 15/03/11
Starbrite instant hull
Mon, 2017-05-15 10:00
Starbrite instant hull cleaner. Can get from Whitworths or any of the Bargain Boat Bit shops. Do a youtube search on the results. I used it to clean the scum lines on my swimming pool that nothing else would touch, worked a treat.
