boat trailer sprinklers
 About to buy a new trailer and have seen a few trailers with a sprinkler system rigged up on them to assist in the cleaning
Have been black poly pipe cable tied on with small sprayers to get the trailer.
Just curious if anyone has done this and has a picture of what theirs look like.
ranmar850's picture
Heard of it done.
Sun, 2019-08-18 17:39
 You would have to be meticulous about placement, or you would be getting dry spots and salt buildup.  I am taking a different approach--ever seen the underbody washes they use on minesites, to clean under vehicles  before they go to the workshop? Process water at pretty good pressure and volume, turn it on, drive back and forward a couple of times. Can't fully replicate this at home really,but don't need to --this week, i am going to set up three of those big stainless Raindrop sprinklers across the drive between the trailer tracks, and  45 degree ones either side, and hook it up to the bore. Our bore water is good, just slightly more calcium than town water, so it's fine for washdown. I'd still rather not wash topsides with it, so I'm also rigging sprays facing down in the big carport, plug into the garden hose,  to wash the topsides down at the same time.  Then all I'll need to give it is a quick wash around the sides and on the deck  with the hose after its parked. Should be a big help wihen we are pulling pots--I spend about 10 minutes washing it down, at least, every day , and I won't have to get down on my knees to wash underneath.
Doing it in the next few days, I'll put up a vid when i'm done ( if it works )
Date Joined: 06/02/14
Keen
Sun, 2019-08-18 19:10
 Keen on seeing results
Tim's picture
Date Joined: 26/09/06
Sprinklers
Sun, 2019-08-18 22:28
Set it up on a previous trailer.
Didnt cable tie it but ran it through the tubes as it is the salt water sitting in there that causes the problems
Just used black polyu tube with the screw in micro sprinklers
Also used the small extension dripper tubes to spray into the cross members
Date Joined: 09/03/13
 Hey ...you say previous
Mon, 2019-08-19 08:42
 Hey ...you say previous trailer ...did it last longer or just different boat now?
Tim's picture
New
Tue, 2019-08-20 18:18
Got a new boat.
Pld trailer was in great condition and was noticed by the buyer.
Was definitely in better condition than the previous trailer without the sprinklers
Going to add them to the new trailer soon
scubafish's picture
Date Joined: 15/08/12
Try
Mon, 2019-08-19 11:09
Try just washing it down(trailer) straight way after it goes in the salt water when you launch & retrieve your boat.
People forget that your boat sits in the backing sun after you launch your boat and all that salt drys on the Trailer.
http://img.gg/BQ91Sys
 Mate of mine has a chemical
Mon, 2019-08-19 15:16
 Mate of mine has a chemical pump pack filled with water in the back of his ute. He uses it to give it a quick rinse. Particularly the brakes.
black gen's picture
Date Joined: 13/04/11
Good in theory scubafish but
Mon, 2019-08-19 14:04
Good in theory scubafish but not always a fresh water tap where we launch our boat
but yes that would certainly help
Belly Fish's picture
Date Joined: 09/03/12
Not convinced its worth it
Mon, 2019-08-19 15:46
I have seen it setup, but I haven't spoken to anyone who said it's categorically extended the trailer life.
The issue is this...
In order for it to make any real difference, you would need to run it for quite a few minutes after launching your boat. Who has the inclination or time for that, even if you have facilities to hook it into??? And, if you have time and facilities, just use your normal washdown gear and give it a good wash.
In my view the biggest single trailer life extender is aluminium and stainless steel!!! Yes, there are steel parts, but at least on my trailer the are easy to replace.
Date Joined: 21/05/12
 tectyl is a product  u can
Mon, 2019-08-19 17:38
 tectyl is a product  u can spray on a trailer or anything metal
there are different grades of it
the viscosity changes with the number
 many years ago.. when the dead sea was only sick
we surf launched boats every day -no chance of  rinse off - limited fresh water - sprayed tectyl once a month -preferably fortnightly, those trailers are still going - they would be on 30 years or  slightly older
couple years ago i was towing drill gear around on a barge
the rods and everything else was pitting - they started spraying tectyl -and saved some $$
one of the range is sprayed once onto farming equipment sitting exposed to salt water on  bulk carriers
they get to the farmer looking like new
I do not work for valvoline!
black gen's picture
I’m aware that fish oil or
Mon, 2019-08-19 19:28
I’m aware that fish oil or fisholene can be put in the acid bath before being re dipped as it all comes off but the galv type paint has to be removed
is tectyl a product that can be put straight into an acid bath or will it need to be removed like a galv type application  if I was getting the trailer dipped
Alpha's picture
Date Joined: 13/02/17
Just finished my trailer
Tue, 2019-08-20 09:13
 Just finished giving my trailer a birthday .
Ive done it to two trailers now with the retick pipe, i just got some black 12mm retick pipe run it inside the box tubes both sides, put a stopper in the pipe on the rear end of the trailer, push a hose connector adaptor that will push straight into the retick pipe on the tow ball end and then clip straight onto your hose, i punched holes all the way up the tube instead of sprinklers i thought that the sprinkler heads will just pull off as your pushing the hose down the box tube with all the wires and corner bends thats in the tube. Its easy and cheap get it all from bunnings. i can clip the hose on walk away do something else while its getting fresh water all around the inside of the box tube. Does it give me longer life out of the trailer mmm well i figger that its got to be better than just putting the hose on the tow ball end and just letting the water run down the to the other end and only getting the bottom part of the box tube.
This time i also have sprayed valvoline tectyl over my brakes and springs to try it out as the reviews looked good. You spray it on black gen its in a spray can. I liked it but its a brown thick film thats left over your trailer which im ok with over the springs and on the inside of the wheels but over the rest of my trailer i wasn't so keen, and it would have been an expensive option to do the whole trailer at about $27 a can.
So i ended using a product called Lanotec its a heavy duty liquid lanolin that you can bye in 5litre container for about $70. I got my garden sprayer rigged a long hose on it put a spray nozzle on the end pushed all the way down the box tube and sprayed a heap into tube as i was pulling it back towards me. put a bucket on the other end to capture the excess.
Blocked all the wholes on the cross members and filled the cross member tubes up to the top again with the garden sprayer, pulled the bungs out captured it all, then dropped the boat in the water painted the rest of the trailer with a brush.
It leaves a clear film over the trailer but its tacky so if your going over gravel or dirt roads it would stick to it. I think i would have to do this process every few years with it as it would wear off but i think it is cheaper than replacing my trailer and hopefully i should get more life out if it.
I still wash it down with fresh water after all that.
black gen's picture
Thanks mateI like the sounds
Tue, 2019-08-20 18:26
Thanks mate
I like the sounds of that
 No need for sprinkler
Tue, 2019-08-20 20:22
 No need for sprinkler systems if you buy an Ibeam constructed trailer. Would never buy a RHS trailer again.
black gen's picture
Ally I beam would be handy
Tue, 2019-08-20 21:11
Ally I beam would be handy but probably out of the price range
not a cheap option
can buy 2 rhs style trailers for the same price  and I’ve gotten 12 years out of this one
black gen's picture
Tue, 2019-08-20 21:12
ranmar850's picture
I have an ibeam trailer
Tue, 2019-08-20 21:02
 Still going ahead with the idea I mentioned above, just to prolong life and give the brakes and springs a good wash every time .
