Boat pulling to the right?
My mates owns a 6.3m Ali with a 150 merc optimax and it pulls severely to the right. It has no power steering. Does anyone know what the problem might be? His motor only has a flat anode mounted above the prop, it doesn't have the fin like this (photo) is it meant to?
Cheers.
RobertMc's picture
Date Joined: 19/01/09
 Yea mate I'm pretty sure
Sun, 2014-03-02 20:35
 Yea mate I'm pretty sure every motor I've seen has one
Vinesh87's picture
 My boat doesnt,  just has a
Sun, 2014-03-02 20:45
 My boat doesnt,  just has a flat disc!
But it doesnt pull  to a side...
Terry's picture
Date Joined: 04/12/05
pitch
Sun, 2014-03-02 21:22
prop pitch, left or right rotation could cause it to turn...un balanced load...too much weight on rh side ? Wind direction...
No power steering ? you mean cable ? or ? That's a big boat and motor with no assist steering.
If none of the above is the problem then...I'm off to bed.
Jayden20's picture
Date Joined: 29/08/11
 unbolt the little anode fine
Mon, 2014-03-03 03:57
 unbolt the little anode fine in the picture and move it one notch over...makes a huge difference
iana's picture
Date Joined: 21/09/09
Funny how people don't read the content of the thread!
Mon, 2014-03-03 06:26
I am thinking that the reason that motor does not have a tab, is that because of the size of the motor, size of boat, the motor manufacturer assumes that a "No feed back" helm would be fitted. Either hydraulic or cable.
I have a "No feed back" helm and have wondered how I would adjust the tab, since the steering is locked when I take pressure off the wheel, there is no way I can tell if the boat is pulling one way or the other, I just set the boat traveling in a straight line and let the wheel go. In other words I could just have the flat anode fitted to my motor that's fitted to your mates engine.
Maybe he could enquire about fitting the same. If its Teleflex steering, they make a NFB helm that fits the cable, or look at a hydraulic system.
I havn't heard of a power assisted helm, but they do come with different ratio's, the skipper has to turn the wheel more for the same response, but its easier to do. hope this helps.
1268-EX's picture
Mon, 2014-03-03 17:47
Thanks for the info guys I'll look into it
1268-EX's picture
Mon, 2014-03-03 17:48
Date Joined: 15/07/12
Trim tab anode
Mon, 2014-03-03 19:16
 Cheap, common. Install with the trailing part of the trim tab fin one or two notches to the side the boat is pulling.
Date Joined: 22/08/12
Yes my merc did the same thing pulled dangerously fast and hard
Tue, 2014-03-11 16:25
to the right. Did as Redchoppa has said and it fixed it but you may find you need more than 1 or 2 notches, I had to move mine to the right alot cant remember how many notches though took me a couple of adjustments and runs on the water to get it right. easy to do also
Luck
Tue, 2014-03-11 19:17
 I got lucky, two notches and she ran straight but prior to that...Right turn, Clyde. And it would happen quickly to.
