boat polish
im after some cutting polish for my boat  gone a bit yellow brown stain from where it sits in the water  whats   the best stuff out on the market for this job
HuggyB's picture
Date Joined: 03/08/08
Off the top of my head
Sun, 2010-01-10 15:57
Meguiars, Mothers and 3M do "marine spceific" polishes, cutting compounds, waxes etc. But really, any cut and polish will do the trick - gelcoats and paint/clearcoat are not too dissimilar.
I'd follow up with a wax to protect all your hard work.
Blank Cheque's picture
Date Joined: 28/03/09
3M Finess it
Sun, 2010-01-10 16:35
Great stuff i was asked if i had repainted my boat after using it.
Garry
use proper stuff, and make
Sun, 2010-01-10 16:26
use proper stuff, and make sure its not like the orange stuff, it will discolour the boat especially the rubbers
southcity104's picture
Date Joined: 27/01/09
Streaker id recomend
Sun, 2010-01-10 17:18
Begin with a liqht acid wash to remove stains (peter G's Clean a hull) works well
Then follow up with a wax restorer like (malco rejuvenator) Much cheaper than 3m finnese-it products and works as well.
Use a lambs wool buff and some technique
If this doesnt bring it up then you may have to apply heavier compound polish.
let us know how you go.
"Its a life style job"
streaker boy's picture
Date Joined: 23/05/09
thanx guys and yeah i know
Sun, 2010-01-10 17:20
thanx guys and yeah i know  not 2 use those orange 1's
i got some  of this boatcare fibreglass polish extra cut in the morning and started on it   but i dont think its 100%
grayzeee's picture
Date Joined: 09/07/09
i got told to avoid anything
Sun, 2010-01-10 18:08
i got told to avoid anything with canuba  in it.
discolours the glass or something
shammy's picture
Date Joined: 03/07/09
polish
Sun, 2010-01-10 18:58
After I did the cut and polish to get rid of all the old rubbish, I used Maguires and it worked a treat.
That's my choice.
"Life wasn't meant to be a spectator sport"
Date Joined: 01/02/09
IMAR Yacht polish
Sun, 2010-01-10 19:31
You buy this at Wilson boating in freo you can get there off Catalano drive they are on the street inside Freo Boat club. All the pro boat detailers use it.
Date Joined: 02/01/10
Any further reccommendations
Sat, 2010-10-16 15:50
Any further reccommendations on a boat polish. I wanna get the missus to polish my vessel
Are these products one application, or are there 2-3 steps?
Brody's picture
Date Joined: 06/02/07
I'd suggest copious amount
Sat, 2010-10-16 16:14
I'd suggest copious amount of alcohol if you want to lure the missus into polishing your vessel.
hekser's picture
Date Joined: 31/03/10
LOL
Sat, 2010-10-16 16:24
gold.
Ha ha, here I am at work,
Sat, 2010-10-16 16:50
Ha ha, here I am at work, and she is home drinking my beer
will see how it goes
nico's picture
Date Joined: 17/08/10
polishing
Sat, 2010-10-16 17:03
Depending on the condition of gel / paint and how fussy you are you might consider wet n dry from 800g to 1500 then cut then polish the key is to wax though this is the sealer.Most peopole finish on a polish and say job done not so wax will gloss it more and help to bead water for a longer duration. This process of waxing must be applied  every 3 months to protect the exterior all the polishes mentioned above will work and the tip on peter g hull wash is gold wear gloves!!.Never wash yo r boat in cheap detergent as it will strip the wax and polish straight away a lot of hard work for nothing  the exterior finish is just as important as that on a car and for resale it is wise to keep it maintained good luck.Wink
In Mocean
Brody's picture
Good luck mate.
Sat, 2010-10-16 17:54
Good luck mate.
