Boat Leaking
Submitted by Josh-759 on Sun, 2017-06-25 16:17
Hello All
Got a quick question regarding a leaking 480 quintrex coast runner. It started all of a sudden one day got back to the ramp and around 20liters came out didnt think to much about it untill the next trip out and the same happened.
So i started to try and find the problems ripped up the floor and started filling with water to see if any water was visable on the outside of the hull... Nothing....
Noticed there are some spots where paint has started to bubble and the bungs dont leak.
Its got me stumped. Any suggestions?????
Cheers Josh
Dustymongrel
Date Joined: 05/03/11
Check where your bung is
Check where your bung is attached to the hull. Might need some new silicone.
Josh-759
Date Joined: 23/10/16
Already replaced the bungs as
Already replaced the bungs as i thought that would be the problem obviously not. Any other ideas??
kuzi
Date Joined: 29/10/12
Bung plugs or bung assembly?
My boat was taking in water recently also. The paint under the bung assembly was bubbling causing water to leak in from under the bung assembly. Removed them and installed new assemblies using marine sikaflex as mentioned in another comment on this post. All good now.
piston broke
Date Joined: 05/11/08
Get the hose
out, fill boat, look for water coming out underneath
Paul_86
Date Joined: 27/03/09
My 480 quintrex had water
My 480 quintrex had water coming into the hull somewhere too, turned out that one of the bolts holding the motor on wasn't sealed properly which let the water slowly seep in
Josh-759
Ill give the bolts a look
Ill give the bolts a look cheers
Silicon
Do not use silicon, its acid based, use marine Sikaflex.
Josh-759
Stoinka
Date Joined: 02/09/06
I found the water
coming in from my drain scuppers on the port and starboard side. The white plastic had a crack on the thread under the locking nut.
Took them both out and welded them both up. Has been a few boats come to grief from the fault. Quintrex did not want to no about it.
Good luck.
Mick C
Date Joined: 26/12/13
Check for Cracks
As Piston says. Weld them up.
Ability is what you are capable of doing. Motivation determines what you do. Attitude determines how well you do it - LH.
If you do find cracks I can
If you do find cracks I can weld for you.
Feral
Date Joined: 01/11/06
Has the hull got
Has the hull got electrolisis or spots of white powder on the inside of the hull? Sometimes filling the hull up with water wont cause enough pressure for water to seep out but when on the water its got a lot of pressure to push it in ..
if possible lift a hatch in the floor near the rear and reverse the boat and trailer into the water , leave it attached to trailer and jump in , look in the hatch , if water runs down the inside of the hull to the back then you probably have pin sized holes under fuel tanks etc up front
Josh-759
I've completed ripped up the
I've completed ripped up the floor so should be able to see where it's coming in. What should I do if they are pinholes
Daryn
Date Joined: 01/05/12
The scuppers were the source
The scuppers were the source of a leak in mine. There is a hose from the outside scupper connecting to the drain on the deck. It had a split in it.
Josh-759
Cheers everyone. Going to
Cheers everyone. Going to chuck her in the water once I've finished guttering it and hopefully find the holes. What should I do if they are pin holes???
D_d_001
Date Joined: 09/03/13
any decent ali welder will be able
any decent ali welder will be able to fix pinholes
just make sure they drill them out oversize first to get rid of any corrosion ....then reweld.
happens to many ali boats.
EDIT: just realised its a quinny.: how thick is the hull ?
Josh-759
Im pretty sure its 3mm bottom
Im pretty sure its 3mm bottom sides. Definitely not any thicker.
Darren253
Date Joined: 23/07/16
Mine was the same. Found the
Mine was the same. Found the lower motor bolts to be leaking. The silicon had completely broken away from the hole. Best way is to fill it up on the trailer. I had to get water up to the floorboards for it to really start flowing.
