Boat latch or boat catch?
 Howdy all, im looking at setting up my trailer with either a boat latch or a boat catch system. The boats a 23 ft caribbean and weighs around 2 tonne i would imagine. I would like to hear from anyone who has either of these systems amd how they rate them.
Or if there are any other alternatives on the market now i would be interested in those too :)
Tight lines.
Date Joined: 29/03/13
 G'dayI've read quite a few
Mon, 2017-06-19 08:02
 G'day
I've read quite a few threads on the topic and you'll find that both brands have happy owners, never heard a negative comment from an owner of either.
I had an L and R Boatlatch on a previous boat (600c Northbank), loved it and never had any issues with it.  I do like multiple attachments between boat and trailer when not in the water though and would always do the ready launch detachments with the stern in the water but the bow where I could release the chain and winch cable without the need for wet feet.  I've heard of and seen pics of a couple of bar crushers (bar catch) which use a similar principle (spring release) where they either forgot to remove the motor flag and drove up the ramp with the catch in release position and the boat dropped on to the ramp.  I think you would have to slam the brakes on hard to get the boat to roll up the trailer on the ramp.   Normally only driving with it in the Latched position and other attachments, shouldn't be an issue but something to be mindful of.
The boat catch, I've looked at and not to keen on the dangling string personally and depending on how that relates to trailer wheels etc, owners will enligten I expect.  I have read one post where a person was going to fit a Boat Latch but fitting wasn't easy on his setup so he went for the catch.
I think the L and R is a fair bit cheaper but you may need the larger model
I'd have another but now have a cat on skids and it just wouldn't move easily enough to be practicle so the wife is back in boots
Rod
Willlo's picture
Date Joined: 07/10/11
 I've just installed a
Mon, 2017-06-19 09:28
 I've just installed a boatcatch system works great.Main reason for installing was for solo launch so i can release the boat with the string from the jetty no wet feet.
 Call Sign - BZ785
Haynes Hunter Prowler CC
Date Joined: 24/03/13
Boatcatch
Tue, 2017-06-20 13:44
Been using the boatcatch for a few years and pretty close to the best boat thing I have ever bought. Launch and drive on retrive very easy, keeps the wife out the way which keeps us both happy. The string isnt an issue and you can use from the boat or jetty whatever you like. I have a Reef Runner.
Jackfrost80's picture
I have a Boat Latch. Drive on
Tue, 2017-06-20 15:53
I have a Boat Latch. Drive on is excellent but I haven't used the drive off yet. I do think the Boat Catch is a slightly better system due to the positive locking mechanism but I couldn't fit it due to my sealed hull below the bow eye and I needed to replace my winch post to fit it above the bow eye. Too many $$ to justify
Willlo's picture
 Jack i had the same problem
Tue, 2017-06-20 18:17
 Jack i had the same problem so just welded an extension onto the existing post and took out one eye, works fine.
 Call Sign - BZ785
I have a weird winch setup.
Tue, 2017-06-20 18:33
I have a weird winch setup. Had to make a custom 15mm plate for the boat latch overhang
Willlo's picture
 Lol yep that would put the
Wed, 2017-06-21 13:37
 Lol yep that would put the brakes on that idea
 Call Sign - BZ785
gruntre69's picture
Date Joined: 15/10/16
I like this one
Tue, 2017-06-20 20:14
 If I had the spare coin I'd buy this
katchya.com.au/
Vinesh87's picture
 I have one of these.
Wed, 2017-06-21 16:06
 I have one of these. Reworking it atm as my barwork for the winch is too big but the above trailer should be ok. The eye might be a bit far away for Katchya?
Date Joined: 02/11/09
 Get yourself a boatcatch.
Thu, 2017-06-22 03:13
 Get yourself a boatcatch. Lifetine warrenty, works great! Mine has been awesome and I would definatly get another.
Date Joined: 06/02/11
boatlatch
Thu, 2017-06-22 08:58
 i have a boat latch unit available if you want one
Cheers rob
Jayden20's picture
Date Joined: 29/08/11
 Thanks for the feedback
Tue, 2017-06-27 05:44
 Thanks for the feedback guys. Boatcatch is definatly looking like the better option.
What size do you have rob? And what are you wanting for it? Pm me if its easier
latch
Wed, 2017-06-28 21:22
 it came of a 6 meter boat and chasing 150
