boat carpet
 Hey guys
Anyone out there know the easyest way to get boat carpet out of fibreglass boat that has been glued down.
Any surgestions would be great. I want to rplace it with stuff i can remove
tilbs
grantarctic1's picture
Date Joined: 03/03/11
Hard job
Mon, 2011-07-25 23:00
Hard job to do Tilbs. If its contact glue only solvent's will remove it, but on fibre glass i wouldn't recomend that path.
Elbow grease might be the only way, rip it up and scrape the glue off. Then sand back the last bits.
Another member might have a better idea, best of luck.
Cheers Grant
strike_zone's picture
Date Joined: 09/09/10
heat gun
Mon, 2011-07-25 23:15
use a heat gun it softens the contact adhesive and allows you to pull it up
Date Joined: 28/03/11
ok
Tue, 2011-07-26 14:52
cheers for feedback guys will try both those techniques.
tilbs
Simon C's picture
Date Joined: 01/05/07
Petrol will work, just not
Wed, 2011-07-27 06:41
Petrol will work, just not sure how good it is for the fibreglass??
Wed, 2011-07-27 08:51
simon c
will try a little bit and see how it goes.I suppose it's not much diff to spilling a bit of fuel when filling up.
not a good idea
Wed, 2011-07-27 09:03
i wouldnt do that deliberetly petrol and fibreglass and flotation ect dont go together to well unless you want to make some home made napalm
Wed, 2011-07-27 14:56
Strike zone will take that on board.i might just try a light grinder wire brushing then pressure kleen the rest and see how i go.
