Battery Advice...
Submitted by chookc on Sun, 2014-12-14 21:39
Hey Guys,
After advice on battery purchase for my boat. Both Batteries have died won't accept charge...
I have a 250 verado which the manual says i Need a min of 1000 cca for starting purposes..
The batteries have been in the boat since new and where fitted by the dealer..
The old batteries were only 900 cca
Is this an issue.
Have done a little searching online for batteries but not having any luck for this size.
Are there any brands to stay clear of and what brands seem to be best...
It runs a duel setup. basic sounder two radios and a sterio and usual lights etc....
jamey ford
Date Joined: 25/05/11
Caterpiller sell 1000cca
Caterpiller sell 1000cca battery nv777z size 4wd quite reasonable priced try the catshop had a couple of them for different uses very good batteries
Far Quirk!
Vinesh87
MCA OR CCA?
MCA OR CCA?
iana
Date Joined: 21/09/09
Plenty of info on the net on this.
May I suggest you do a search "250 Verado battery", there are bulletins, and answers to other owners asking the same question.
grantarctic1
Date Joined: 03/03/11
I cant help
I cant help with what size and type you need but can suggest buying factory direct from Supacharge in Bayswater. I am not affiliated with them but after a few crap batteries i go straight to them now for advice and factory direct prices.
I have bought a couple batteries online, only to find out they were older stock and they crapped out fairly quick.
Cheers Grant .
VaSSagO
Date Joined: 09/12/09
Another option is Goldchilds
Another option is Goldchilds Enterprises in Jandakot.
I picked up these for $194 each, ~1050 MCA
http://goodchild.com.au/marine/bosch-battery-s4-78.html
Gotta give them a business name to get that price (make one up) but can pay cash / card.
chookc
Date Joined: 07/01/10
not sure what mca is but
not sure what mca is but defin 1000 cca Cold cranking amps.. Will look at the verado stuff again..
Are supercharge still on beechborra rd south?
joel231
Date Joined: 18/09/12
If your after some CAT
If your after some CAT batteries, i would suggest the one with part number 115-2422. These are 1000cca and rated at 90amp hours. And according to my cat login they are available in the guildford store and are $230 each plus GST maybe. Never bought stuff from them only through work but pretty sure you can order and pay on pickup if you want.
Cheers Joel
jamey ford
Yep thats them joel and if
Yep thats them joel and if you know someone that works for cat the discount for staff price is bloody impressive.
Far Quirk!
fuzzy79
Date Joined: 31/07/10
If your battery drops below
If your battery drops below 10.6v on start up, the 250 verado's engine management shuts it down. Hence the requirement for powerful batteries.
I put Fullriver AGM batteries in my boat (with 250 Verado). Best price is Challenger batteries in Osborne park.
