Anchor issue how much chain not setting properly
Submitted by poser on Mon, 2013-09-16 10:20
hey fellas havin anchor issues just wondering how much chain users are running from the rope to anchor as I believe that's where my issue is. cheers again
Size
How big is your anchor and also the size of you boat.
poser
Date Joined: 25/01/13
5.2 meter my anchor is lost
5.2 meter my anchor is lost some wear in cockburn sound lol so wanna buy right anchors and chain this time
Troy Summers
Date Joined: 14/08/11
try this out
try this out
The chart doesnt specify an
The chart doesnt specify an anchor type? Huge difference in holding power between say a danforth and Delta or Sarca.
Really depends what the purpose is also, id say 9 meters of 8mm chain for a 6 meter boat is at the upper end of whats needed if its just for fishing rather than overnighting.
For fishing id use 6 meters of 6mm rated shortlink, much easier to retrieve
Problem solvered
Problem solved, thanks Troy
Jason P
Date Joined: 16/02/13
My setup
My setup uses cheap 10lb plough anchor with 8m of 8mm chain for a 5.1m Quintrex. Works great.
DM306
Paul H
length of rope out is equally
length of rope out is equally important 3x the depth is usually the rule in normal conditions (ie 90m or rope out in 30m of water)
snappermiles
Date Joined: 05/11/10
buy a sarca
best anchor out add three metres of chain and your away add to that the right amount of rope and you will anchor anywhere
petermac
Date Joined: 03/03/10
sarca
how do they go in reef
Vinesh87
Perfect, they stay on the
Perfect, they stay on the boat and you drop the reef anchor.
They are verexpensive to lose!
snappermiles
i drop mine in reef all the time
as long as its not huge nigga heads they have no worries just drive forward of the anchor and up she comes
