VRO Oil tank difference
Submitted by davidbland50 on Fri, 2012-11-09 22:57
Good evening fellow FWers,
Just wondering is there a difference between VRO pumps that are in the tank between a 1993 150hp Johnson and a 1998 90hp Evinrude? I have just purchased the latter type and was going to fit it to my 150. The only difference I can physically see is the tank is considerably larger. Any advice would be a great help. Thankyou.
mr_meks
Date Joined: 11/02/11
There is no pump in the tank,
There is no pump in the tank, just a level sensor. A bulb primes the oil to the vro pump, which is part of the fuel pump assembly on your engine.
davidbland50
Date Joined: 24/07/11
Ta
Thanks Mr Meks,
So it should have no bearing on the performance of the VRO system, therefore. I will be changing back over to using the VRO system next week and looks as though I have kept the integrity of the system since I disconnected.
