VHF radio problems
gday all, Just noticed the vhf radio in my boat was working properly just wondering if I am up for a new one or it is a simple fix. Was working fine till yesterday. Now turns on, but cant read any numbers on the screen, and only hear static. cant change channels or seem to be able to transmit or anything. Its a GME brand probably about 10 years old.
cheers for any tips
Throw it
Mon, 2019-01-21 14:03
Not worth trying to fix. Wouldn't spew in emergency situation if it didn't work.
Time to swap it out.
Mon, 2019-01-21 14:27
And buy an Icom
Mon, 2019-01-21 14:42
Far better quality build and worth every cent
Heck before you ditch it
Mon, 2019-01-21 20:58
Heck before you ditch it check that you have a decent power supply to it.
Those issues are exactly what my furuno was doing here at Rotto.
Turned out the fuse had a bit of corrosion on the pins and while it had 13 volts on the bus bar, as soon as it was turned on it dropped to 10 volts and did exactly as you described.
Check the easy simple and cheap stuff first.
Having said all that GME aren’t the best brand for reliability...
Date Joined: 04/09/16
thanks for the feed back Rob
Tue, 2019-01-22 06:47
thanks for the feed back Rob and others, will try suggestions before the upgrade option. cheers
gruntre69's picture
Date Joined: 15/10/16
 Yep my GME acts like that
Thu, 2019-01-24 21:34
 Yep my GME acts like that with low voltage. But if it has shit itself I'd buy an Icom
