Using MB-1100 matching box
Submitted by Banksy81 on Wed, 2017-07-05 14:14
I have a FCV 620 is it worth getting a matching box and 1kw tranny?? Or do i bite the bullet and upgrade, either to a 588 or the simrad s2009.
User loginNavigationSearchWho's onlineThere are currently 2 users and 3258 guests online.
I have a FCV 620 is it worth getting a matching box and 1kw tranny?? Or do i bite the bullet and upgrade, either to a 588 or the simrad s2009. |
Marineboy
Date Joined: 14/03/14
Matching box
you can run a compatible 1kw Tranny without a matching box on a 620 but the head unit is only 600w, you will get a better reading with the 1kw Tranny over a 600w but to take full advantage of the 1kw the 588 would be better.
hope that made sense.
mark
Banksy81
Date Joined: 25/05/13
yeah mate thought as much
thanks blair
Tim
Date Joined: 26/09/06
As above
Info above is correct. 620 works well with a 1kw
You only need the matching box when wiring up non diplexed transducers like the bare wire commercial units
Banksy81
sweet so the 525TID-TMD 1kW
sweet so the 525TID-TMD 1kW should work or TM260 would also do
JohnF
Date Joined: 07/07/10
You will get 90 percent of
You will get 90 percent of the benefit from running the 1kw tranny on the 620. I almost never run more than 600 W gain on my old 587 even in deep drop, so the 1 kW. Output is a bit of a. Lot point.
Scotte
Date Joined: 07/12/06
John the gain doesnt change
John the gain doesnt change the output power it only changes receiver sensitivity..
