Trailor brakes
 Hope someone can help me out.
when it comes to trailor brakes what is the minimum requirements to get a trailor licenced that is rated for 2000kg
E.G. Drum on both axles , Disc on single  or electronic.
Also what are peoples thoughts on using led lights on the boat trailors, are they suitable or just go with the standard ones.
Date Joined: 23/04/14
Requirements
Sat, 2017-07-08 01:52
 Over 750 and up to 2000kg - single axle brakes, over-ride brakes permitted.
Over 2000kg - all wheels must be braked, must be an electro-hydraulic or similar system, must have a breakaway mechanism.
All info is here - http://www.transport.wa.gov.au/mediaFiles/licensing/lbu_vs_ib_107.pdf
There are other experts on here like Rob H who can give more details.
Your dominator
Sat, 2017-07-08 07:46
Disks on front . Axel only. All you need.
just dhu it's picture
Led lights
Sat, 2017-07-08 08:07
make life easier for your self and install marine LED trailer lights , most units are brighter than standard globes and wont have any issues with lamp holders rusting up .   Make sure all connections are soldered and where possible keep away from water imersion spots
Vinesh87's picture
 Disc on front as big as
Sat, 2017-07-08 10:04
 Disc on front as big as possible. Def dont go drum they trap water. I would opt for hydraulic over mechanical
Led for sure
 trailor has got hydraulic
Sat, 2017-07-08 11:02
 trailor has got hydraulic drum and we have been quoted $1200 to $1300 for all new disc brakes and mechanisms  as well as led lights . all fitted.
so wont be me bodging things up on the brakes
had the trailor bloke say thats all i needed as far as brakes and lights go then the trailor will pass over the pits.
just wasnt too sure as its a bit confusing about all the info on diff sites you look at
thanks to all
