trailer wheel bearing grease??
What grease are you using and do you recommend it?
I have been using that blue castrol stuff in the tube from MTP.
Found it to be rubbish.
Any heat at all and it melts out.   ( as in a 40 deg day and a short tow to the ramp)
Looking for something with better heat resistance.
Date Joined: 30/03/10
use htb cant go wrong there
Thu, 2013-03-07 20:53
scotto's picture
Date Joined: 21/04/08
Good question.
Thu, 2013-03-07 21:05
 I've asked this at a few bearing/mechanic/trailer part places, and I've got the same answer every time : marine grease is what should be used in boat trailer bearings.
from a dinghy, to a tri-axle 4 tonne boat, even if you have to travel 2000kms before your bearings get submerged into salt water, a marine grease is a better than a HTB for this application.
i have also gone away from bearing buddies, as consensus is that they allow dirt/grit to enter the bearings more readily, they can potentially blow out the rubber seals, and that you only gain an advantage from pumping them up just before you back your trailer into the water.
I can verify first hand, that a set of bearings / condition of grease, using a dust cap, looked better after 12 months, than a set of bearings / condition of grease, using bearing buddies.
Vinesh87's picture
I am running marine grease,
Thu, 2013-03-07 21:01
I am running marine grease, with dust cap.
Was thinking of going to Dura-hub.. Not sure !
JohnF's picture
Date Joined: 07/07/10
Agree grayzee, the blue
Thu, 2013-03-07 21:17
Agree grayzee, the blue marine stuff struggles with heat. Option is to keep pumping in new blue grease all the time or use HTB grease which does not like moisture but better with heat and keep pumping in the grease.
Bottom line, keep pumping grease in and regularly pull the bearings out, clean and repack.
And DON'T back into cold water with hot bearings.......
Vinesh87's picture
Don't back into cold water
Sun, 2013-03-10 12:27
Don't back into cold water with hot bearing, as true as it is im not going to wait for my bearings to cool down when im at the ramp haha!!
Cruise Control's picture
Date Joined: 03/11/10
 Nulon High Pressure grease.
Thu, 2013-03-07 21:40
 Nulon High Pressure grease. Its red, its sticky. copes with heat and when I was doing my own bearings, I never had a problem and I towed 2-3 tonne boats all up and down the coast.
sstevee's picture
Date Joined: 15/11/11
Bel-ray waterproof grease for
Thu, 2013-03-07 22:29
Bel-ray waterproof grease for me... Had it in a set of bearings that did perth to exmouth and back and perth to kalbarri and back... Was recommended to me by a guy at martins trailers and I won't be using anything else from now on...
leesfishin's picture
Date Joined: 27/03/11
+ 1 for bel-ray waterproof
Sun, 2013-03-10 12:21
+ 1 for bel-ray waterproof great quality grease, is a bit expensive but ok if you buy bulk on line (bikebiz.com.au) has it for $13.95 +post
The yanks have a good setup
Sun, 2013-03-10 14:53
The yanks have a good setup which allows you to pump fresh grease right thru your bearings, for some reason no manufacturers here have adopted similar.
marble's picture
Date Joined: 03/09/09
Got that on our trailer, a
Sun, 2013-03-10 15:26
Got that on our trailer, a grease nipple on the end of the axle that allows you to pump the grease to the back bearing, seems to work pretty good so far ( 4 years) I pull apart and repack or replace every 6 months, cant be too careful when its a biggish boat and hot weather.
dan1's picture
Date Joined: 11/07/07
htb
Sun, 2013-03-10 19:58
I go the htb as the water will mix with that grease where as the marine grease it will not so if you do get water into your bearings and park the boat up for a while you have a better chance.
as the marine grease will let the water sit on top and rust your bearing where if you have htb the grease has mixed with the grease and you might have a better chance at repacking your bearings just cleaning the grease out
Buz's picture
Date Joined: 28/08/07
Same. Both me and my brother
Mon, 2013-03-11 15:04
Same. Both me and my brother use Penrite HTB on both of our boat trailers and no problems 10 years on. Try to repack/new bearings once a year but more often do it once every two years or just before a big tow trip. Also using bearing buddies and just repump a bit of new grease into the hubs after each time out.
Vinesh87 mentioned it above
Mon, 2013-03-11 14:21
Vinesh87 mentioned it above and I would also be keen for any feedback - has anyone used or uses durahubs ? What are they like for reliability ?
