Trailer maintenance advice
Submitted by greyheads1 on Mon, 2020-12-14 14:06
I'm just experiencing a few issues with brake seize (intermittent failure to release or partial application) on an electrically braked trailer. Issues arent consistent which suggests a connection issue somewhere. Can anyone receommend a mobile mechanic (I'm north of the river, Sorrento).
Alan James
Date Joined: 30/06/09
If it's an electrical issue
you would be better off with an auto electrician. I used Towsafe a few years back to install new brakes and bearings and they were good (not cheap though) but I still needed to engage an auto electrician to tidy up a few electrical issues.
J Mann
Date Joined: 02/09/15
Trailer guy
Have used Darren from DTL a couple of times 0428 100 518
Tawihiri
Date Joined: 07/12/14
Circuit board
Check if there is circuit board in the reservoir . Had one go on a long trip as moisture had gotten in and ruined it. Was about $400 to replace. Sounds simliar to what happened to mine .
greyheads1
Date Joined: 27/08/11
Great, thanks for the advice
Great, thanks for the advice guys. I'll try each suggestion sequentially until a solution is achieved!!!
The initial seizure was all brakes, but 1 km into journey after stoppping to check connections etc. I switched it all off and unplugged, restarted (switch off and on) all worked fine for next 15km.
On return, it was one wheel of the four (twin axle) that applied a partial brake for 5-6km? weird.
