Trailer info-anyone who has a 2000kg plus trailer please!
You guys who have a 2tonne plus trailer, do you have any sort of handbrake fitted on it?
Lamby's picture
Date Joined: 04/08/09
Nope
Sun, 2013-06-09 22:55
Nope
thanks mate, just completing
Sun, 2013-06-09 22:59
thanks mate, just completing my trailer upgrade to 3 tonne and the hitch has a handbrake handle fitted but I was sure Brett Martin told me to just cut it off.
Probably over the pits tuesday, tomorrow need to get the new Cruiser into WA rego also so its a busy couple of days dealing with our local one man show for licencing
outdoinit's picture
Date Joined: 05/10/12
+1 Our trailer is
Sun, 2013-06-09 23:01
rated to 3500kg and no handbrake fitted..
thanks Lyndon, Ill chop the
Sun, 2013-06-09 23:30
thanks Lyndon, Ill chop the handle off!
Vinesh87's picture
 Yeh mines chopped off!
Sun, 2013-06-09 23:41
Date Joined: 10/02/12
None on mine either.
Mon, 2013-06-10 09:04
 No handbrake fitted on mine from new.
Terry's picture
Date Joined: 04/12/05
mine has one
Mon, 2013-06-10 09:18
and I use it all the time. Whats to stop the trailer running away when it's not on the car ?
We use the one on our car don't we ?
Vinesh87's picture
 A brick
Mon, 2013-06-10 11:04
 A brick
Cruise Control's picture
Date Joined: 03/11/10
Im rated to 3000kg and I dont
Mon, 2013-06-10 12:36
Im rated to 3000kg and I dont have one. I reckon if it did I would def use it. Saves chasing around for a brick and could avoid an embarrassing situation like almost happened to me. Unhitched and the trailer slowly started to roll backwards. Ever tried to stop 3t of rolling boat by yourself !
The Saint's picture
Date Joined: 30/01/13
Not on Mine
Mon, 2013-06-10 12:42
Don't see how it could be done really. Even if you could do it, it would only work until the battery was flat !
Bodie's picture
Date Joined: 05/11/07
Saw a couple try retrieve
Mon, 2013-06-10 13:35
Saw a couple try retrieve their boat on Saturday afternoon at woodman point, of which the trailer had a hand brake and it was on whilst trying to retrieve.
The lady jumps in the Ford Sedan.....Puts it in drive....realises the boat is pretty heavy and rolls back a bit on the ramp.... decides it gas it... IT was like watching a burnout at the drags!! not seen smoke come off tires like that since i was a teenager!!
Bloke jumps off the boat giving the missus a grilling before he realises he fked up anbd left the tralier hand brake on!
What a crack up.
Cut it off i reckon! mine doesnt have one
Lamby's picture
LOL
Mon, 2013-06-10 21:14
LOL
chookc's picture
Date Joined: 07/01/10
if you have override electric
Mon, 2013-06-10 18:46
if you have override electric brakes then it won't work..
If you have cabled brakes leave it on...
thanks guys, have it sussed
Mon, 2013-06-10 20:52
thanks guys, have it sussed now.
brick does it for me but I was more concerned with the licencing of it.
pelagicyachts's picture
Date Joined: 23/02/11
you can pull your brake away
Tue, 2013-06-11 09:39
you can pull your brake away lanyard in the event that you need too stop your trailer (trailer starts rolling) - noting that i dont mean that you can use it as a handbrake!! - seperately its also worth doing this once a month, the calipers have a bad habit of seizing or getting sticky if not used regularly -a lot easier than hitching up the rig and driving around the block!
