Temporary boat removal from trailer
 hi there,
i I need to do an overhaul - major - on my trailer made all the parts and ready to go really need to remove boat from trailer and store for a week or so any suggestions?
paul
scottnofish's picture
Date Joined: 28/08/07
you can just take
Sun, 2015-05-10 08:10
 The boat off and sit it on some old tyers seen it done that way heaps .I did my 7 m cat with jack stands anb some rubber matting just tied the boat to another car and drove the trailer out put ing stands underneath  as i went every couple of meters. Then when putting back on thd trailer i just whinched the new trailer in removing the stands as i went easy as
this thread of mine has a bit
Sun, 2015-05-10 09:21
this thread of mine has a bit on getting my boat, 2.5 tonnes off the trailer
Probably took an hour or so to get off and not long to get it back on.
http://fishwrecked.com/forum/antifoul-removal-sodablasting-etc-updated
z00m's picture
Date Joined: 10/05/14
 You could also hit up one of
Sun, 2015-05-10 10:13
 You could also hit up one of the lifting yards if they have a boat rack and they can usually do you a deal for a few days or a week.
I recently did mine as an overnighter at Mindarie Marina. Very helpfull folks there let me put the boat in one of their overnight pens.
clarky29's picture
Date Joined: 15/04/15
 Just go down to the local
Sun, 2015-05-10 15:23
 Just go down to the local tyre shop and get some old tyres stack them two high and  put the boat on them.  We did this a couple of weeks ago and it worked a treat.
clarky29's picture
Paul Jackson's picture
Date Joined: 19/04/09
 Sounds like a plan - any
Sun, 2015-05-10 18:26
 Sounds like a plan - any tips for getting it back on to the trailer or is it real straight forward
Date Joined: 20/01/14
Here's how I did it
Sun, 2015-05-10 20:48
Hooked on to the stern of the boat and pulled it back about 1.5 metres, jacked up the back of the trailer then made two stackes of old tyres, one each side of the keel, take out the jack and move the trailer forward leaving the boat behind. Just before the keel drops off the trailer make another two stacks of tyre to support the bow. To reload the boat  I hooked the winch rope on and pulled the trailer and car back under the boat using the winch, getting it on was easy.
Ian
clarky29's picture
 As Ian said just  backed the
Sun, 2015-05-10 20:57
 As Ian said just  backed the trailer back under while winching at the same time
Thanks for the help and
Sun, 2015-05-10 23:37
Thanks for the help and guidance guys - I will get onto it
Was quoted a ridiculous ammout to repair trailer, so manufactured the replacement cross beams and he only obstacle was removal of the boat so that I could sort out the trailer.
Only expensive part has been galvanising the beams.
Will let you all know how it goes and pop u a few pics
Paul J
Date Joined: 10/06/09
i know someone with a private
Sun, 2015-05-10 23:41
i know someone with a private jetty in mindarie could tie it up there for a fee
