Sting ray problems
Iv been out a few times trying for something bigger off the rocks (metro area's) and i just seem to be getting hammered by stingrays. Iv tried different baits and rigs but still get the run around by the rays.
Anyone got any tips on what rigs to try and baits?
fatboyholla's picture
Date Joined: 20/05/11
ive been floating my baits
Mon, 2011-10-17 20:32
worst fisherman ever
deepwater's picture
Date Joined: 09/05/07
Sting ray problems
Mon, 2011-10-17 21:00
how about live bait under a float ,along the same lines as fatboyholla
       jeff
Willlo's picture
Date Joined: 07/10/11
Not sure what rig you are
Mon, 2011-10-17 21:08
Not sure what rig you are using but if you have a 3 - way swivel .Try a small cork set up on your leader line at the eye of the hook.Then have a slightly longer trace to your sinker ,the bait should float up away from the bottom. Also works ok if there is a bit of weed around.
 Call Sign - BZ785
Haynes Hunter Prowler CC
Markie's picture
Date Joined: 06/08/10
 Basically as everyone has
Tue, 2011-10-18 07:32
 Basically as everyone has mentioned get it off the bottom and you are most likely never to hook up a ray again. Searching for sharks? Balloon it if possible with a good 2/3 metres of line under the balloon with a wire trace of course.
jphall's picture
Date Joined: 23/09/11
Thanks for the advice!Yeah, i
Tue, 2011-10-18 09:07
Yeah, i never thought of floating it up of the bottom. In Europe when fishing for pike they use pop up floats which you attach or insert into the dead baits, can you get them here in Australia?
Date Joined: 15/08/11
 its funny i thought a float
Sat, 2011-10-22 23:14
 its funny i thought a float would work as well until i caught 3 in an arvo on live herring under a float. Honestly if theyre hungry enough they'll come off the bottom(usually only eagle rays as they dont mind being off the bottom) its not as common but it happens trust me, best thing you can do is keep at it and eventually after you filter through enough rays you'll hit a keeper! don't lose hope!
 By the way fresh bait always
Sat, 2011-10-22 23:17
 By the way fresh bait always helps it wont stop the hordes of rays but it will make it more tempting to that prized mully!
boonmack's picture
Date Joined: 31/07/11
you should just enjoy
Mon, 2011-10-24 17:27
you should just enjoy catching the rays,
 its better than a kick in the ass or nothing
wish I was fishing
ben89's picture
Date Joined: 10/05/11
Id be happy with a ray lol,
Thu, 2011-11-03 12:37
Id be happy with a ray lol, something to peel some line off my reel and give me a fight
Date Joined: 15/06/11
^ +1
Fri, 2011-11-04 11:49
^ +1
NEVER argue with idiots, they bring you down to their level, and beat you with experience.
jphall's picture
Yeah dont get me wrong, i
Mon, 2011-11-28 19:40
Yeah dont get me wrong, i like catching them but when i do i have'nt a clue what to do or how to handle correctly to un-hook.
Sharktale's picture
Date Joined: 13/07/11
Don't flip them over 'cause
Fri, 2011-12-02 12:37
Don't flip them over 'cause you'll injure them internally. They do wan't to hit you with the tail so keep it down with a rod holder. Remove the barb of your hooks for starters and make yourself a tool like below (will also help with sharks)
"I FISH, 'CAUSE THE VOICES TELLS ME TO...."
Jabba's picture
Date Joined: 26/08/09
 Stop fishing 1/4 moon
Fri, 2011-12-02 14:44
 Stop fishing 1/4 moon phases....
