Solar charging question
We're running a dual battery system through a voltage sensitive relay. All works well. The second (house) battery is a big deep cycle which we'll use to run an Engel during an upcoming trip. We're going to run a 120 watt solar blanket as additional charging to the engines alternator.
I'm wondering whether it's ok to run the panel at the same time as the engine is charging or is it a case of one or the other, but not both Thanks in advance, John.
Swompa's picture
Trusting you are running
Tue, 2019-02-05 12:33
Trusting you are running through a regulator, I cannot see there being a problem.
The regulator will stop the battery overcharging.
Feral's picture
Date Joined: 01/11/06
 Check with your motor
Tue, 2019-02-05 13:59
 Check with your motor manufacturer. Some motors have smart alternators and they might cancel out thinking its fully charged because the solar is connected .. Usually Id suggest only using the solar when the motor is off as its only putting in 6amp versus your alternator putting in 60 odd amp..
Stevo81's picture
Date Joined: 16/04/12
I run this on my 300Ah house
Tue, 2019-02-05 20:09
I run this on my 300Ah house bank. Takes the voltage from the alternator when its running or the solar from the 150w panel if its not and provides the house AGMs with their ideal charging voltage. Works great.
www.enerdrive.com.au/product/epower-dc-to-dc-battery-charger-40a-plus/
 i run the same in my camper,
Tue, 2019-02-05 20:12
 i run the same in my camper, great bit of kit
