running vhf antenna cable and radio power together
moving the vhf radio to a new location and this would have the antenna cable and radio power cable side by side from the back of the radio for about 1 mtr.
does anyone know if this would impact on the radio performance or is the antenna cable shielded enough that it wouldnt interfere weth performance . There isnt enough room to run the cables any other way.
Paul
Thu, 2017-02-23 07:27
 I don't think there will be an issue, the power to the ham radio in my car runs along side the coax going to my UHF/VHF antenna at the front with no issues.
Date Joined: 09/11/06
Thanks Dale
Thu, 2017-02-23 08:51
Thanks Dale
Taffy's picture
Date Joined: 04/11/10
If IT does cause
Thu, 2017-02-23 11:51
 If it does cause a problem ,
just buy yourself a few Ferrite clamps off ebay and attach then to both power and coax cables ,as close to the radio as posible, wrapping the wire as many turns as possible through the ferrite
            AND Gday DALE if your reading this
Thu, 2017-02-23 12:10
 Howdy there Paul, all is good, hopefully it is your way too, radio land has been a bit quiet though.
Taffy's picture
Been Flat Out
Thu, 2017-02-23 21:23
 Been Flat out Here Dale, Programming Commercial radios is never ending,
i will try give you a bell if i can find your number
