Posts out of order
 I've had an issue for a while, where, seeing a new post on a thread I've been following, I go in, only to find no apparent new posts? I've just realised that the new post is there, but buried somewhere up the page, only can be determined by looking at date and time of posting. seems to happen to me a lot, anyone else seeing this?
Nimbin 157's picture
Date Joined: 03/05/10
 May be replies instead of
Sat, 2017-03-25 21:03
 May be replies instead of new comments
 If you click on the "1
Sat, 2017-03-25 22:01
 If you click on the "1 reply" rather than the post itself, it should go straight to it, somewhere at the top of the page unless its a huge thread like the footy ones then it doesnt work.
In tiny letters on the right side it says "new" but so minute you need a magnifying glass to see
Bones 79's picture
Date Joined: 12/02/14
 As rob said a reply will be
Sun, 2017-03-26 13:16
 As rob said a reply will be up the page somewhere because it is to do with another post but a new post will always be at the bottom of the page and the easiest way to get to the new post is to click  on the "1new" hope this helps
adam
