Oxidation - Cut and Polish help
Need help re polishing fibregalss boat.
Boat sat for a few years up north in the sun and has heavy oxidation (boat is dark blue). Have tried to cut and polish with several brands, it seems the polish just gets absorbed into the surface and results in extensive swirls - tried by hand and machine. I don'tpolish in the heat or direct sunlight.
Trying get boat up to specs to get back on the water.
Any tips appreciated.
2 Pack
Fri, 2011-01-28 16:40
Sounds like its time to give it a new coat of gelcoat or 2 pack paint.
Date Joined: 09/01/11
try a product called marine
Fri, 2011-01-28 20:17
try a product called marine finess but be warned it contains silica so you need to wear dustmask/respirator we have just done a quick polish on a baron and it took of all the sun fade. once my camera has charged i can post some before after photos
Date Joined: 04/07/07
Finess
Fri, 2011-01-28 20:54
2 votes for 3M Marine Finesse - $20 from Whitworths, will give it a go.
Cheers - will post the result (good or bad).
Borbs
nico's picture
Date Joined: 17/08/10
mmm got your work cut out on
Fri, 2011-01-28 22:50
mmm got your work cut out on that one mate hard cut polish and wax use a buff machine hand job would be a waste of time. A dark coloured hull like that will need wax every 8 weeks to keep a good shine the gel looks a bit far gone from the pic bu you may be lucky keep us posted.
In Mocean
this is a before photo we
Sat, 2011-01-29 14:31
we polished most of the hard to get to parts by hand and the rest got a light buff with 3m marine finesse
 this is after we havnt done the bottom yet as next weekend we are putting it on a new trailer and will do it then
a little elbow grease and it will look good as new
