New power cable for Furuno GP7000F
Submitted by stevo58 on Wed, 2018-01-17 14:05
Gday All,
Just wondering if anyone has a spare power cable for a Furuno GP7000F plotter....my plotter keeps turning itself off....was told it is likely a problem with the power lead. Local Furuno dealership is out of stock to mid Feb....so just chancing it on here....
cheers in advance
Steve
Stevo81
Date Joined: 16/04/12
Have you checked the
Have you checked the connections of where the Furuno cable picks up its power from and also the pins on the Furuno cable & unit? Make sure there’s no corrosion
Jadeo
Date Joined: 08/06/15
Run a multimeter on your
Run a multimeter on your battery and check for voltage spike or drop when it is dropping out. Sounders are a bit temperamental when it comes to volts so they can protect themselves. If it does spike or drop, could be your voltage regulator/rectifier that is the the problem. Off the top of my head I think the range is between around 9 - 14 volts. Anything out of that range they will shut down
stevo58
Date Joined: 07/01/16
thanks for tips guys will
thanks for tips guys will check those things
stevo58
streaker boy
Date Joined: 23/05/09
TRy ch smith they have them
TRy ch smith they have them n will post
stevo58
just ordered one from
just ordered one from them....thanks guys !!!
stevo58
