Need to work on trailer ....where can I put the boat ???
Submitted by Krusty on Sat, 2016-03-26 17:50
Hi everyone,
I need to do some work on my trailer and I need the boat off the trailer while I do this.
There is no way I can remove the boat at home and was wondering what people do when they are in this situation ?
It will take me the best part of a day to do the work I need to do so need somewhere to "store" the boat for a day !!
Any suggestions would be much appreciated.
Thanks,
Steve.
meglodon
Are you Nth or Sth of the river
When had to do some work on my trailer I went and asked the local marina if I could use a per for less than 24 hrs they let me have it for a super cheap rate. I live at Falcon if you live near a marina you may have some luck trying the same thing.
Katman
Date Joined: 22/08/14
I had to do same a little
I had to do same a little while ago and was able to leave my boat at the boat rack / ŕepair jetty at Hillarys marina.
Im sure if you ask around down there they could be able to assist
Krusty
Date Joined: 27/11/15
I am SOR and my closest ramp
collin g wood
Date Joined: 18/04/11
Leave it on the centre pier, no probs
Krusty
Good thinking there collin,
Good thinking there collin, that could be just the thing
Tim
Date Joined: 26/09/06
Done
Krusty
Yep that's what I intend to
Yep that's what I intend to do tomorrow.
Cheers.
SpotHound
Date Joined: 06/02/14
Mandurah
Mandurah ocean marina is about 90 bucks per day, if you pay by the day.
z00m
Date Joined: 10/05/14
Freo
Bit of a hike but might be worth it. I did mine at hillarys and tied up to the walkway so it wasn't in anyone's way. Just make sure you have exactly the right tools and probably 2 of some. I had my rubber mallet break the head off on the first hit removing the trailer bunks!!!! Could have been worse, the guy next to me had dropped his keys in the water so his keys wouldn't start the car!
Also, don't forget the bung. Since it isn't a normal outing you can forget the simple things....Murphy and all that!
Krusty
Yea that's a bit far really
Yea that's a bit far really but good suggestions there about taking more than I think I will need. It should be a simple straight forward job but we all know how those "simple" jobs turn out at times.
Thanks.
woodywantstofish
Date Joined: 11/09/13
If you know someone with a
If you know someone with a dam . I find that works well. Can get a bit of tanin staining though.
epic restos and...
Date Joined: 22/06/15
if you need a spot look us
if you need a spot look us up always happy to help
Krusty
Cheers for the offer there
Cheers for the offer there mate but should be all good.
I will be in contact with you in a couple of months or so (when I save some coin) to chat about putting a hard top on my boat if that is something you would do ?
Been watching your projects and they look great....keep up the good work.
Cheers,
Steve
Krusty
Thanks for all the
Thanks for all the suggestions people and for the offer epic but I will do what collin said as that should do just fine.
Ericl
Date Joined: 02/05/11
Trailer repair
Hi Krusty
If you haven't sorted this yet, I have a boat lifting device that can handle up to about a 23 foot boat, 24 at a push. It lifts the boat off the trailer and you then pull the trailer out and drop it back again when you are ready. I am North of the river
Eric
Krusty
Thanks for that Eric, my
Thanks for that Eric, my boat is a cat though so not sure if that would work ?
Anyway, I am hopefully heading down to the ramp tomorrow and floating the boat off and doing the necessary work in the ramps carpark.
Cheers for your offer anyway and if I run into trouble I could be in contact.
Steve
Subaquatic
Date Joined: 23/04/11
I have the same problem. The
I have the same problem. The hump in the middle of the trailer makes it a very difficult lift.
I used Mindarie a few weeks ago, just tied up to the wall along the shopfronts, and did the work in the carpark.
