Lowrance GPS not working (help needed)
Submitted by TAPOUT on Mon, 2017-05-01 06:46
Hi all. I have just purchased a second hand lowrance GPS LMS 525. I have the LGC-3000 receiver but cannot get the unit to pick up the receiver. I have the T price and cables to suit but still not working. Any ideas? Maybe someone has the same receiver I can try plugging in to rule out my receiver being stuffed. Also on another note I have the (HDS 5X gen 2) and cannot get it off split screen. I've googled it but still can't figure it out.
I would appreciate any help. Cheers
silly
Date Joined: 02/01/09
Make sure you've got
Make sure you've got terminals on both end of the T-piece which completes the network, Also pretty sure you can select the LGC antenna if it comes up in the network settings too.
Tim
Date Joined: 26/09/06
Power
Make sure you have set up a second power supply for the network.
The LMS wont power the network from the head unit
Darren253
Date Joined: 23/07/16
Second that
Both of the above comments are 100%, I struggled when bench testing before I realised that you need to power the network...
TAPOUT
Date Joined: 27/01/06
Thanks for the info guys.
Thanks for the info guys. Much appreciated. I followed your advice and wired in a separate power source and it worked perfectly. Huge relief.
I still have the sounder stuck on split screen if anyone has any ideas. It's just been one of those weeks haha.
Goin_Fushin.
Date Joined: 07/12/13
Split screen ?
When you say split screen do you mean viewing two things at once (map and sounder) or on the sounder screen full depth and bottom lock (bottom plus a few metres above)?
willy2668
Date Joined: 18/10/11
Factory reset
Factory reset
