Lowrance fuel meter calibration
Anybody had any luck calibrating a Lowrance fuel flow meter on a HDS 9????
Full 100lt tank,sensor measured 80lt when pumping it out via an electric pump.
I followed the on screen prompts,it doesnt seem to go past the info box.
I will admit I havent told the HDS that I have filled the tank yet,its siting empty on my workshop bench.Perhaps you can only calibrate if the HDS THINKS its got a full tank????
Andrew
Date Joined: 03/03/10
as a instro
Sun, 2014-01-26 21:07
it will need to know when its empty and full you really need to do a 4 point cal if you want any accuracy
LandyAndy's picture
Date Joined: 22/02/09
Thanks Peter,by 4 point
Mon, 2014-01-27 15:53
Thanks Peter,by 4 point cal,do you mean over 4 fills????
Andrew
a four point cal
Mon, 2014-01-27 20:23
I could actually do you a four point cal with out you putting any more fuel in your boat based on the amount of fuel already have on board
Date Joined: 24/04/11
Fuel Flow
Tue, 2014-01-28 07:38
Is this the fuel flow meter, not tank gauge?
I calibrated mine on a HDS7 without any problems.
Its been a while, but I filled the tank and zeroed the fuel used.
After Id used 100 liters or so, I filled the tank and did a recalibrate, where you enter the amount of fuel used (from the fuel bowser). This is a bit of an iterative process, so it took 3 or 4 fills before it was reading accurate, but it now accurate to around 1 liter over 100-150 liters of fuel used.
