Legal # of hooks
G'day...
Quick question for ya's...
What's the maximum legal number of hooks you are allowed to fish with on one line?
How are snelled/ganged/trebles viewed in light of the rules (are two snelled hooks on one dropper loop classified as two hooks or just the one?)?
Might be a silly question... but I'm currently knocking up some traces (swells a wee to big for me)... and I'm snelling two hooks on one dropper; two droppers per rig... and in the back of my mind I'm thinking 3 is the legal max. # of hooks allowed on one rig... so am I over?
cheers,
damo
boofhead's picture
Date Joined: 13/03/08
i've had in my mind for some
Sat, 2008-07-05 18:32
i've had in my mind for some time now that you cant gang together more than 3 hooks but i dont know for sure....but the other day i was going through a small tackle box i forgot i had and found a gang of 4 so got me thinking........  dont know why i been thinking 3.....
boofhead's picture
thats a good point.... might
Sat, 2008-07-05 18:39
thats a good point.... might have to do a bit of research and find out.... just out of interest
Maverick's picture
Date Joined: 06/06/06
Snell
Sat, 2008-07-05 19:39
For ballooning big gars etc we use to gang a 7/0 ( in the head) 3 X 9/0 ( thru the body)then another 7/0 (in the tail) and a big 9/0 treble at the end,so 5 hooks and a treble to make up 1 bait .
________________________________________________________________________
 Oatsfishwest member 88 .
 OFW member 088
Auslobster's picture
Date Joined: 03/05/08
I seem to recall hearing
Sat, 2008-07-05 20:37
I seem to recall hearing somewhere that you can have a maximum of 4 hooks to a gang. You can use mono/snells instead of gangs for your big baits, but toothy fish would be a problem....does anyone know if it's possible to tie snells with "knotable" wire? Then there'd be no need at all for gangs, and no wondering how many hooks are legal?
Maverick's picture
Steel wire
Sat, 2008-07-05 20:42
I snell hooks in 7 strand and 49 strand wire , no problems , I don't really like the gangs where you put the hook thru the eye of the other hook , I don't think I get as many hook ups to the snelled hooks , only time I do hook to hook is when using single strand wire .
JMHO
 OFW member 088
boofhead's picture
i only use ganged hooks when
Sat, 2008-07-05 20:44
i only use ganged hooks when going for tailor salmon etc..... maybe i should try snell
cheers Jes
"I got a new rod and reel for my wife
...best trade I ever made."
hlokk's picture
Date Joined: 04/04/08
Doesnt andys supersneel use
Sat, 2008-07-05 21:56
Doesnt andys supersneel use some wire (ends up inside the squid)?
There is knotable steel wire that you can snell with, then theres the lock weld stuff you may be able to use (not sure about snelling with it though).
I have actually snelled a hook using single strand wire to see if you could do it and it seemed to hold up ok, but I havent actually used it in practice. I guess you could weight test it first though and be reasonably confident.
edit: you could rig a sliding snell for the top hook, and the bottom hook as usual with a crimp (or a haywire if using single strand). Though, the bottom hook needs to be on for the the second to stay (say if it gets bitten off). Though, I guess using wire it shouldnt get bitten off and you could use a stopper crimp anyways.
I use some thinner mono for the sliding snell (when on mono), but it tends to seize a bit after a lot of use, so gone back to  fixed snells til i can find something better. Heatshrink perhaps?
Always interested in someone to go fishing with
Bit of an aside but those
Sat, 2008-07-05 22:11
Bit of an aside but those Owner boa rigs are pretty interesting. Its a moveable knot that you can set to your bait length with a  bit of stuffing around.
hlokk's picture
Tried some of those, but the
Sat, 2008-07-05 22:36
Tried some of those, but the mono is a bit thin and the knot doesnt work anywhere near as good as you'd think. Cant get it to move after hand tightening, so i wouldnt trust it budging after a fish. Plus the bottom hook does not have an eye, just a flattened head, but the edges are sharp and can cut through the mono. I love their hooks and other terminal tackle, but some of their other stuff hasnt quite been up to the same standard.
