Help Please. Need Hydrive bleeding hose/bottle/nipple
Submitted by Grumpysmurf on Wed, 2014-08-27 11:46
I am hoping someone has installed a Hydrive hydraulic steering recently and still have the refill / bleeding kit (bottle cap with clear hose and nipple etc) lying around.
I need to bleed mine and cannot find the kit.
Haines Signature 610C with Mercury 150 EFI
Muppet
Date Joined: 23/11/09
just make one up
get a bottle, nipple and piece of hose from super cheap and way you go.....
are you talking about the ram end or the helm end ?
Grumpysmurf
Date Joined: 26/02/09
Helm end - need the nipple
Helm end - need the nipple which screws into the refill port and plug the hose into.
DTrain
Date Joined: 10/02/12
I did mine recently and used
I did mine recently and used a funnel which I jammed into the refill hole. It worked ok without spilling too much.
The trick is to turn the wheel quickly to get all the air out the lines, while still keeping the funnel topped up.
my one (Seastar I think) is
my one (Seastar I think) is just a bsp thread. Take the plug to a bolt shop and should be able to get a hosetail for a couple of bucks.
Marineboy
Date Joined: 14/03/14
Bleeding hose
I have a bay star one, should be the same.
Live in hamersley.
barneyboy
Date Joined: 08/01/09
A funnel does the job
that air has to come out somewhere!!
FEEEISH ONNN!!!
RobertMc
Date Joined: 19/01/09
Where are you located
wagyl
Date Joined: 08/03/09
Different size tube
Is available at Clark Rubber or Whitworths can't remember which but I think Clark Rubber, and I just bought about a foot of each size, one fits perfectly in the helm hole, drill a hole in a plastic bottle cap and wedge the other end in. Put the fluid in the bottle and turn upside down, you then have a perfect filler for the helm.
davidbland50
Date Joined: 24/07/11
I have it
PM me if you live nor.
Grumpysmurf
Thanks guys - I will try and
Thanks guys - I will try and make do without the proper fitting (Will probably spill 2 litres of fluid all over the carpet!
aweall
Date Joined: 16/11/10
i have one i live in
i have one i live in forrestfield
Bruzoandnicko
Date Joined: 02/07/12
Adapt, Improvise, Overcome.
