hds problems card detail
hi guys,
i have a hds 7 that i run as a gps and it seems every time i turn my unit on. the gps fires up and everything works but i have no detail like running the gps with out a card! if i remove the card then insert it again the detail pops up! has anyone had this problem and what have they done to fix it??
cheers jeff
Vinesh87's picture
Just a stab in the dark but
Tue, 2012-08-07 17:32
Just a stab in the dark but is your gps losing total power, e.g battery getting isolated and it's losing its memory of the card being loaded and when you put it back in it just re loads it ?
snappermiles's picture
Date Joined: 05/11/10
it still shouldnt
Tue, 2012-08-07 17:47
loose the background detail! i disconnect the gps every time! itr never did loose the data before its only just started doing it! but thanks
tombstone's picture
Date Joined: 14/10/10
 all i can suggest is maybe
Tue, 2012-08-07 21:08
 all i can suggest is maybe your contacts are either losing touch with the card or a bit of corrosion is setting in?
 to fish or not to fish...as if there was an option.
no corrosion tombstone
Tue, 2012-08-07 21:12
the card and the contacts are in tip top shape! but cheers
harro's picture
Date Joined: 07/02/08
snapper
Fri, 2012-08-10 14:34
have you triend some of the other maps? you may have corrupt data,
save all ur points and do a reset mate, prob the only suggestion I have,
 :::: Bass Hunter ::::
na i havent tried other maps harro
Fri, 2012-08-10 14:56
as i only have the one chart which does the wa coast! but cheers il try the reset trick!
It doesn't have an internal battery does it
Wed, 2012-08-15 14:30
I ask as my old Garmin had a built in internal rechargable lithium battery to power the memory back up when disconnected and it died, they simply replaced it and after charging it was back sweet again..    You could NOT access that battery without pulling the unit apart
Just a thought as it might explain the issue - am not familiar with your unit or it's internals
