Furuno 600L help
Furuno 600L sounder went haywire yesterday and displays 500 metres in Hillarys harbour ! anyone seen this happen before ? transducer or electonics fault ? and any recommendations for a repairer ?
TIA
Cruise Control's picture
Date Joined: 03/11/10
 Sounds like it's searching
Sat, 2018-06-09 22:30
 Sounds like it's searching for bottom. All connections tight ? Is the transducer still in the correct position ?
 Have you got it set on auto
Sun, 2018-06-10 08:55
 Have you got it set on auto range or something?
Try the obvious shit first like set the depth on screen manually, gain down, plugs cleaning.
Ive no idea how much you know about setting them up but this link is good
http://www.fishtec.co.za/furuno_setup.pdf
If it’s a electronic problem, they just aren’t worth fixing, better getting another one as the 600 is pretty old.
Great sounder though, I only replaced mine with a 620 as it packed up.
$350 I think and it’s still all I use
Date Joined: 24/11/09
Furuno 600L
Sun, 2018-06-10 09:46
Checked that the tranducer is solid and appears OK, tried the auto and manual settings and it didn't make much difference so suspect the Electonics, does any one run this model that I can confirm/test ? looks like an update to 628
 Think the 620 also runs same
Sun, 2018-06-10 20:13
 Think the 620 also runs same 600W trans, should be a few members with those here in your area?
Mines in Gero and Im even further away at work!
