fuel sensor not reading
Submitted by Glen.vit on Sat, 2015-06-20 20:16
Hello just wondering if someone could maybe help me, just recently i noticed my yamaha fuel gauge was reading empty when i know i got half a tank still available. I thought maybe my float was stuck but after removing it and cleaning the sensors im still not able to get a reading.
Any info on this would be great.
Marineboy
Date Joined: 14/03/14
Yamaha gauge
does it read anything when the tank is full ?
did you try opperating it manually when the sender unit was out of the tank ?
just dhu it
manual
is you yamaha gauge have a tank sender ( resistive sendor ) or do you put in the amount of fuel that the tank holds and when you re fill and it reads how much the enginne is using to give you a level in tank picture meaning there is no tender sender unit
Glen.vit
Date Joined: 11/01/11
Cheers for your help fellas.
Cheers for your help fellas. My float was buggered, ended up buying a wema sender and shes working all good now.
