Fuel overflow
My Quintex sports is leaking very minutely from the black outlet in the pic on one side of the boat and fairly consistent drip, I'm assumeing it's from a full tank/flow, however it hasn't in hot in Perth so not sure any idea's ?
TIA
Date Joined: 03/08/19
Had occasional similar
Mon, 2025-08-18 17:42
 Mine does the same in summer if it's hot and tank is full, so I only top it up with a jerry can the night before going out. I also found I could often stop it by winding the trailer down at the front, which likely  changed where the fuel level sat near the breather outlet. Might be worth a play around with that.
 I have the same and as
Tue, 2025-08-19 07:38
 I have the same and as Reefsta above says. It sounds like it's just full.
I've literally just pulled my tank out for repairs as the welds around the pick up and breather have corroded
. Need to get it repaired, was quoted $650 the main charge in that is the degas. Getting it doen for piece of mind.
