Fuel Filter
 Hi folks, can you tell me the pro's & con's of putting an inline fuel filter in after the seperator between the primer pump and motor.
Had problems with gummed up carbies the last time i went out. Had it all cleaned & repaired with new gaskets & parts, but would like the security knowing that nothing is going to get into them again and spoil a nice day out before it begins.
Was probably related to just sitting around for 10 months with a start in the driveway every month.
Your help in this matter is greatly appreciated as usual.
Cheers.
Cheers & Stay safe
Lavs's picture
Date Joined: 30/04/12
You’re probably right that
Tue, 2019-04-09 14:39
You’re probably right that the 10month sit was the cause. It happened to me. Mechanic recommended using F10 in the fuel all the time as a preventative.
Date Joined: 16/05/09
Run the fuel out of the motor
Tue, 2019-04-09 14:57
Run the fuel out of the motor each time you use it on carby motors.
dmck's picture
Date Joined: 07/03/19
drain the carbies..
Tue, 2019-04-09 16:02
 Running them 'dry' worked for me for over 20 years with no probs.
SOme people believe the gaskets/seals will dry out and fail but it never happened on my 1986 90hp Yamahaha
