fuel cap seals
Submitted by scotto on Mon, 2010-09-27 08:58
hey mofos.
I've got 2 x 80L stailess steel cruise tanks, and both the seals/gaskets/o rings on the fuel caps need replacing. i think they are made of cork.
does anyone know where i can get them from, or if i make my own, will the cork gasket sheets from supercheap auto be ok?
scotto
i think cork would be ok
i think cork would be ok but you could also use rubber, cut a couple out from an old tyre tube and give it a go. another one is the rubber o rings you can get, take the cap along to an auto joint or even a plumbing joint and get the o ring to fit
dodgy
Should be able to get fuel
Should be able to get fuel resistant gasket material from CBC bearings or similar.
