Fluorocarbon leader help for bream fishing!
G'day all,
              Need some help from those in the know! I want to start trying out Bream fishing, have my rod and reel 2-4kg range and just purchased some 8lb Suffix performance braid. But what I want to know is about the Fluorocarbon leader.
What lb rating leader should I use, a higher or equivilant rating as my braid, what length of leader do you use and which fluorocarbons would you recomend.
James
Colin Hay's picture
Date Joined: 23/10/07
Try Berkley vanish
Mon, 2008-02-11 11:32
A lot of breamers use it.
incompleat_david's picture
Date Joined: 10/01/08
hey, if your after a fluro
Mon, 2008-02-11 12:20
hey, if your after a fluro carbon give The Sufix Flurocarbon a whack its great stuff in the lighter side of gear perfect for that rating of braid :)
Compleat_David
Compleat Angler & Camping World Joondalup
PH: 9300 2588 FAX: 93000202
Blake.T.'s picture
Date Joined: 12/12/07
Hey mate, i have used
Tue, 2008-02-12 20:15
Hey mate, i have used vanish, yamatoyo(spelling???) rock fish, seaguar, nitlon and line systems for bream fishing. My favourites were the yamatoyo rock fish and line systems which can get a bit expensive, but well worth it. I normally don't find the need to go higher than 6lb. 4lb is good for fussy fish on the flats or in the open. I wouldn't go higher than 8lb or you start to lose some finesse.
Hope this helps mate.
Blake
P.S. give breammaster.com a look, it has most of the breaming community on there.
Date Joined: 04/11/07
Vanish or Seaguar for me
Mon, 2008-02-11 16:08
Yes, Berkley Vanish or Seaguar do the trick for me. Have a mate thats fishes alot of the bream tournaments on the east coast and he swears by the vanish. He has about 8 rods with him when he goes, all rigged for different situations eg fishing snags, rocks, sand flats, soft plastics with different weighted jig heads etc etc. (lucky his wife doesn't realise the cost!!!!) Always tries to use at least the same breaking strain as his braid mainline and up to about 8lb max. I think Blake.T is spot on the money mate.
Good luck champ!
ezza
honsu chin's picture
Date Joined: 20/09/05
I would probably use 8lb
Mon, 2008-02-11 16:15
I would probably use 8lb braid and work to heavier leaders as needed. Alternatively you could go lighter if the fish are really spooky and just backed the drag off to compensate for the ligher leader. 8lb main line doesnt always mean you have to fish to that.
I use Line System Egi FC leader, Sunline Rockfish FC leader and YGK Nitlon DFC.
Manager/Tackle Rat @ "Oceanside Tackle & Marine"
364 South Street, O'Connor, Perth Ph# 9337 5682
Maverick's picture
Date Joined: 06/06/06
Nitlon / YGK
Mon, 2008-02-11 20:05
TROUT soft DMV nylon , it's not fluro but Ultra soft for knot strength and ultra tough and hi abraision resistant for pulling fish out of structure and UV resistant as well , I used it up on the muzza's the other week and recon it holds knots better than the fluro's I have .
I can not see the line in the water and the dams are crystal clear .
A little cheaper than fluro too.
JMHO
MAV.
Anyone else tried it ?????????
 OFW member 088
skinny's picture
Date Joined: 08/11/07
fluro
Mon, 2008-02-11 20:50
i used yo-zuri hybrid fluro because it comes in 250 meter spools for around 20-30 bucks!good option, i used about a rod length of leader.about 8 pound for structure fishing 4-6pd flats fishing.
jimbo1's picture
Date Joined: 22/12/06
Whats the difference between the two
Tue, 2008-02-12 10:49
What is the difference between the two different types of fluorocarbon?
Fluorocarbon tippet
Fluorocarbon leader
I ask as was looking on ebay for fluorocarbon and they had vavaris as fluorocarbon tippet line from US for $10 posted. Only 30m but thought was cheap to try and at 6.2lb measures  .219 mm . Seems to be of similar diametre to the seaguar and other fluorocarbon, but would it only be suited to fly fishing?
 This is the stuff.
http://www.fly-fishing-tackle.co.uk/acatalog/varivas_tippet.html
THE LAZY FISHERMAN * Proud supporter of BAILEYS BAIT BOX * MSN/
Date Joined: 01/01/70
for me!
Tue, 2008-02-12 09:38
I use a rods length re fluro leader, open water 6lb and structure i use 8-10lb......if spooky you can drop back!
I use Linesystems fluro, Sufix and Vanish!
Owner/Operator "Oceanside Tackle & Marine"
bear's picture
Date Joined: 30/03/06
I've been using the Yamatoyo
Tue, 2008-02-12 11:07
I've been using the Yamatoyo now for about 4 years and have been very happy with it. I notice that even BCF have started to stock it if you find it hard to get.
HTH.
I Live in My Own Little World,
But it's OK, They Know me Here.
WABT Tournament Director
WAFM Writer
Tackle Rat :-)
Owner - Ranger188 VSI
brenz's picture
Date Joined: 15/06/06
i like the new td fluro
Tue, 2008-02-12 13:26
i like the new td fluro carbon im using 6lb rodlenght and had great results
brenz
supported by:THE TACKLE SHACK: 9248 3800
                    BOAT CITY 9345 4311
