Fcv587 deep water setting
Submitted by jng on Tue, 2014-04-01 21:09
Hi guys,
can anyone tell me what deep water settings they are using on thier furuno 587 and tm260
went out last Friday and tried the 587 in 200+ of water, it picked up the bottom fine but the screen was full of clutter even with 0 gain, tvg was set to high and running it on 50khz, tried changing the clutter and other setting it didn't clear it at all
tranny is a tm260
The unit works exceptionally well on 200khz up to 150m, once it's changed to high tvg it just clutters up.
Thanks in advance!
Justin
Scotte
Date Joined: 07/12/06
gotta be going dead slow.
gotta be going dead slow. not sure how fast your trying to sound?
jng
Date Joined: 03/08/07
Going very slow, even on the
Going very slow, even on the drift it was still cluttered
grayzeee
Date Joined: 09/07/09
Dunno if it's too much
Dunno if it's too much different from my 585 and tm258 but I can't run high tvg in 50 khz.
Has to be low or medium (which ever gives best pic, just adjust gain to suit) and 2/1 scroll rate with black background .
As little clutter and colour erase as you can manage and range shift in to remove most of the water column.
As above - go dead slow or it's all over.
That's the best I have been able to get mine
jng
Yeah I tried it on medium
Yeah I tried it on medium tvg, it does read the bottom but I have to crank the gain up very high. Might just have to leave it on medium
Scotte
Something a bit different but
Something a bit different but i keep it on hf up until 300m tvg high and just up the gain to 6 works well for me..
jng
Might give that a shot, see
Might give that a shot, see how well it picks up the bottom.
Cheers for for the advise
harro
Date Joined: 07/02/08
yo
justin ,
check you clutter settings are 0%,
interference is ok at auto,
TVG - 200M + set to high
if this doesnt work for you, try your 200khz as that will still work in the 200,s
note, sounding on 50khz you muust be going very slow,
good luck
:::: Bass Hunter ::::
jng
Cheers harro I'll try that
Cheers harro I'll try that aswel, next time I'm out.
Dhuvinile
Date Joined: 13/05/12
try also dropping the
try also dropping the transducer ;)
jng
The set up of the tranny is
The set up of the tranny is ok, I have no problems with good picture with my normal settings but once I turn it to high tvg it clutters the whole screen
JohnF
Date Joined: 07/07/10
I run tvg on high in 300 m on
I run tvg on high in 300 m on 50 kHz and get clear screen if running at 5 knots if not too much chop, but have thru hull. You are pushing brown stuff up hill with a transom mount, much harder as any turbulence will show up as clutter.
