Engine Vibration
I have a Merc 175 2 stroke, 2006 model which runs perfectly at speed, idles perfectly, but vibrates like a mo fo when doing less than about 10 knots.  Given it runs smoothly, I have (perhaps incorrectly) assumed it is either a drive line issue or something outside of an engine issue that is creating the vibration.
Has anyone had a similar issue, or ideas as to what to check?
scubafish's picture
Date Joined: 15/08/12
Try
Fri, 2019-12-20 11:21
prop balance & shaft .(maybe bent)
I would go with
Fri, 2019-12-20 17:14
Comment above. Something to do with prop
Date Joined: 02/01/12
Check the plastic prop
Fri, 2019-12-20 20:03
Check the plastic prop coupler block inside the prop, sacrificial item saves the prop and drive shaft in th event of a prop strike. They do age and crack from time to time
