Engine Trim
hi all,
Before my holiday i took my boat out and the trim switch on the control box was no longer working.
The trim switch is still working on the engine.
Do you think i have to change the whole control box? or is there a simple tilt replacement or change the wiring?
last question - do you guys unplug your battery when the boat is not in use? my dads boat got a simple switch that shuts down the power...is it worthwhile investing in one of these?
whats the worst thing that could happen if i dont unplug it
Wiring
Wed, 2009-02-04 21:11
Sounds like a wiring issue if the trim/tilt is still working on the motor.
Battery isolator will help prevent electrolysis occurring if you have an ali hull and something is earthed to it i.e. metal 12 volt cigarette lighter socket.
John
I head a little FURTHER NORTH each year,
Leave the cities behind, out of sight of mind,
NOHA's picture
Date Joined: 24/06/07
Its common for the switch to
Wed, 2009-02-04 22:23
Its common for the switch to fail itself. Open it up and I can bet you its a bit green inside. Should be a replacable part.
No Orange Hats Allowed
V8 twin turbo diesel....Ohh what a feeling!
kane's picture
Date Joined: 07/12/08
Yep, change the switch, they fail regularely.
Thu, 2009-02-05 02:20
You can test the switch, arc a screwdriver across the two terminals with the wiring obviously still connected and see if the trim works, if it does its not the wiring but the switch.
Goooooone Fishin!
Gooooone Fishin!
Auslobster's picture
Date Joined: 03/05/08
Battery Islolator.
Thu, 2009-02-05 05:02
Good idea. I know with the sounder/GPS combo that I have, there is still a power draw even when it's switched off. Had a lot of trouble with batteries being drained before I put in a switch. Could be the difference between a great day on the water or being towed in.
7739ian's picture
Date Joined: 25/06/08
Isolators
Thu, 2009-02-05 05:53
are apparently not foolproof. I was talking to a boat builder/repairer this week and he has had 2 boats in his workshop recently where he could detect voltage down line of the isolator and get cables to arc. Battery disconnection when not in use is his motto.
Isolator is a good idea,
Thu, 2009-02-05 06:16
Isolator is a good idea, prevents electrolysis.
JoRn's picture
Date Joined: 20/11/07
thanks for your replies, i
Thu, 2009-02-05 10:18
thanks for your replies, i will probably just disconnect the battery.
as for the trip, is it easy to take off the switch?
