Electrical issue
Submitted by Bones 79 on Wed, 2017-03-01 20:01
Hi guys
Is it possible for the battery 1,2 on off isolator switch in the boat to fail. I noticed on the weekend that the boat electrics can work when the switch is in the off position this has only just happened as it used to work fine
thanks adam
petermac
Date Joined: 03/03/10
yes it is
all electrial switching mechisams will eventualy fail so yes its possible just put a new isolator switch in and all will be good but sounds like it has just carcked its switcing mechinasim , sorry but one other thing , never never switch your battery isolator switch with the outboard / inboard while its running ,it will draw a large arc because it is under load
A it stuffs your isolator switch
B if you have some fuel fumes floating around your likely to get blowen up
Coastrunner
Date Joined: 25/10/14
Point of failure
Yep, have known corosion in a battery isolator to result in a motor not starting.
Bones 79
Date Joined: 12/02/14
thanks guys what are the
thanks guys what are the better brands to go with
Stevo81
Date Joined: 16/04/12
Blue Sea Systems are
Blue Sea Systems are good
https://www.bluesea.com/products/category/11/Manual_Battery_Switches
or
Or
http://www.bepmarine.com/en/products/battery%20management
Bones 79
Thanks for the info I will
Thanks for the info I will grab a new switch next week and hopefully that solves the problem
