Electric motor help
Hi guys Has anyone had one of the minn kota outboard motor mounted electric motors. Wondering how one would go on my 150hp yamaha for trolling for barra. Boats a 5.8m chivers centre console. Its a big high sided boat. What model do you think i would need and what batteries etc How long will it run on battery Sorry about so many questions just know nothing about electric motors http://www.minnkota.com.au/about/trolling-motors/engine-mount/engine-mount-freshwater.html
Cheers. CCC
Date Joined: 01/01/70
Electric motors..
Tue, 2012-03-13 13:00
I had an inflatable 12 foot boat for the youngster, like a cheap tender, and bought a smaller Min Kota, and it worked okay - but it was the black motor - for freshwater, the white motors are for saltwater... I used a 40 Amp/hour(A/h) battery, and the maths on this is easy - divide the current used at the speed you like to go, by the 40 for example, if the motor draws 1 amp at full speed, it will run for 40 hours - find a mate with a multitester to tell you what it draws at different speeds, but have it in a working position in the water... this is just a guideline, but as you are only trolling, it is not a drama if the battery runs flat... I think the bigger motor is the go, as the difference in price does not justify the problem later. Hard to estimate how it will work, as if you have 2 large blokes on board with heaps of kit, it will be heavier, but will just take longer to get going. 5.8m is a fair size boat for trolling....
Date Joined: 29/03/10
Cheers davebarryYep 5.8 seems
Tue, 2012-03-13 19:21
Cheers davebarry
Yep 5.8 seems big but after fishing the Daly mine doesnt seem that big most guides in the territory are now running 6.5 - 7m boats. Seen one of these outboard motor mounted electrics on a 6m barchruser.
Really interested to see how they go
